Drl's & Fog Lights to LED
Old Jun 9, 2020 | 10:58 AM
silverformula's Avatar
Default Drl's & Fog Lights to LED
I like to change my Drl/Turn Signal and Fog Lights to LED's. As you all know a flasher fuse has to be used to get the Turn Signal to work, my question is - Will the rear tail Lights work which are stock?
Old Jun 9, 2020 | 06:10 PM
VIP1's Avatar
Copy & Paste Moderator
A "no load" flasher will work with LEDs and will also work with incandescent bulbs.
So, yes, you can have LED in front and incandescent in rear.
Just be sure to get a flasher that will work with LEDs.
I have a mix of LEDs and incandescent bulbs.
I'm using a "no load" flasher.
Old Jun 10, 2020 | 03:09 AM
Thanks
