Steps for fixing an obvious scratch in the paint
Old Nov 7, 2020 | 05:52 PM
Rich-L79's Avatar
Default Steps for fixing an obvious scratch in the paint
I've never had much luck touching up paint chips and such. Today I found a scratch in the middle of the quarter panel on the GTO that goes at least down to the primer. So, I have to fill the scratch with paint and then cover it with clear. Is there any way to do this and not have it look like an obvious touch up (I already have plenty of those on the hood). I have some spray paint for the base coat which is a dead on match, so color matching isn't the issue but it is a bright color (Brazen Orange) and a metallic so getting a touch up that blends in is always tough. I do now have a RO polisher which I've learned to use, but I have to get good paint and clear on there first, I just am unsure about not having it look like an obvious "bump" and how to get the paint in there and have to color and metallic line up so as to not be obvious.
Old Nov 7, 2020 | 10:55 PM
themealonwheels's Avatar
Based on how you describe the flaw and the tools/methods you know, only a respray will satisfy. You can try fooling yourself with a quick fix, but I get the feeling you won't be satisfied outside of perfection. Do it once, do it right. Right?
Old Nov 8, 2020 | 12:35 AM
Rich-L79's Avatar
Well, bottom line, I'm not going to paint the entire quarter panel to address this.
