Post Your Modified Cars!
Old Jan 1, 2021 | 09:41 AM
  #41
joeformula's Avatar
Bunch of clean rides
Old Jan 1, 2021 | 01:21 PM
  #42
HAWKVERT's Avatar
Default 2002 SLP Pontiac Firehawk Trans Am #0025
Oh yeah!
Old Jan 1, 2021 | 05:19 PM
  #43
Kjduvall's Avatar
Not Shure if my other toy will qualify for this thread, but it's an LS and very modified......
Old Jan 5, 2021 | 08:38 AM
  #44
firebatbirdv8's Avatar
Default 99 transam
Old Jan 6, 2021 | 06:16 PM
  #45
2JAWZ's Avatar
Originally Posted by firebatbirdv8
How can I get my hands on a set of those tails?
Old Jan 6, 2021 | 06:33 PM
  #46
ramairjohn2000's Avatar
the side **** in the garage is pure evil sickness
Old Jan 16, 2021 | 06:22 PM
  #47
Kjduvall's Avatar
My 00 formula and my buddy's 20ss.
Getting ready to cam the SS.. only has 1,300 mi on it..
Old Jan 17, 2021 | 06:31 PM
  #48
RAMPANT's Avatar
Original owner. 455ci LS7 ITB, lots of stuff to handle. Plus some good tunes.
Old Jan 17, 2021 | 07:08 PM
  #49
lees02WS6's Avatar
My 02, original owner
Old Jan 17, 2021 | 07:58 PM
  #50
SSquicksilver's Avatar
Beautiful!
Old Jan 18, 2021 | 08:25 AM
  #51
Default More info please
niceeeee want more pics info please
Old Jan 18, 2021 | 08:56 PM
  #52
RAMPANT's Avatar
What do you want to know? Lots of suspension, motor etc.
Built to turn and be pretty quick in a straight line.
This is most of it, but there is stuff missed too.
455 ci LS7 705hp flywheel track use.
-LS7 block, Darton MID sleeves by RED.
-Callies Magnum 4.125 crank
-Compstar 6.125 H beam
-Custom Wiseco 4.190 pistons
-MAST LS7 configured cathedral port 275cc Ti Intake -11.1:1 compression
-Harrop Hurricane intake for Cathedral 8 x 55mm intake
-Kooks 2” headers
-Kooks True Duals
Cooling for 30 minutes of WOT driving
-Ron Davis Radiator- largest and tightest packed fin area
-Ron Davis coolant to oil Oil Cooler 14 plate unit
-Hypertech 180 degree T stat
-Spal dual fan unit, with flaps that open at speed, sealed to rad
-Evans ceramic coated and modified LS water pump
-removed AC, and custom made sealed ducting
-removed WS6 power steering cooler and made a remote unit
-modified Canton remote oil adapter 10AN to oil cooler and remote filter
-stock oil pan with Improved Racing baffles
Transmission
-T56 Magnum, F Body fitment, with upgrades(blockers, keys and brass pads)
-McLoed Street Twin with Aluminum flywheels and Miba friction discs.
Front suspension:
UMI RR K Member
UMI RR lower control arms
Global West RR Upper control arms, Delalum bushings
UMI/Strano Afco 800lb springs previous Ground Control Koni Sa 550lb
36mm Hotckis sway bar with rod links Reinforced stock mounts.
Rear Suspension
Mid West Chassis Fab 9 with long TA
Mid West Chassis Watts link
UMI Lower Control Arms
Strano adjustable 22mm rear sway
UMI/Strano Afco 275lb springs previous Koni SA with adjustable perches
Spohn Subrame Connectors
Brakes Wilwood 6 Piston up front, G Loc pads.
Big sticky tires as stated above. Hoosiers, Toyo R888s and a Drag pack. Wheels, 8 x CCWs, 4 Weld RTSs, 4 Torque Thrusts and 4 stock.
Light weight, but 900 watt RMS stereo. Not really track related, but I drive better with tunes.
It needed some help with aero above 130 mph. So the Splitter is functional, removeable and ties into the front bumper mounts.
Old Jan 20, 2021 | 06:55 AM
  #53
probably eBay
