Protecting the Outer Seals on the T-Top
Old Apr 30, 2022 | 07:16 AM
Underwear's Avatar
Default Protecting the Outer Seals on the T-Top
Hey all - can’t find anything on this, plenty on weatherstrips in general… but what do you use to seal/protect/keep black your external rubber around the t-top glass?
Not talking about the weatherstripping underneath the glass… I mean the stuff exposed to the elements all day long.
On my old ‘95 I used whatever tire shine I had, but I don’t know if that’s best. 303 or something silicone based in general? Tire shine? Don’t want to put something on it and it goes all chalky.
Old Apr 30, 2022 | 06:46 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
303 is what I've been using for about 20 years, for ALL of the plastic/vinyl/rubber trim inside and out including the area in question. I also use 303 on the little caps at each end of the metal T-bar between the tops. Those caps are more prone to fade and failure than the outer trim referenced in your post, so might as well treat them at the same time.
Thing about 303 Aerospace though, is that it's not much of a "restoration" product. When you use it on neglected/faded plastic and rubber pieces, it's only a marginal improvement and not long lasting. This is more of a maintenance product, something to use on good condition pieces to prevent them from needing restoration in the first place. A perfect example is the cowl panel that always fades to a light-ish gray on the 4th gens (more visible on the Pontiacs due to fender design); once the typical fade has occurred, 303 isn't going to bring it back to original color and finish. But continual use of 303 (just how often will depend on details of exposure) will prevent the problem before it happens.
Bottom line, 303 = excellent protectant, but poor for restoration.
Old Apr 30, 2022 | 07:42 PM
Underwear's Avatar
Cool thanks! Good call on the little piece in the middle. So just to be clear we’re talking about 303 Aerospace not any of the other 303 products?
Old Apr 30, 2022 | 08:14 PM
RPM WS6's Avatar
Yeah, it used to be called "303 Aerospace" but now it's just called "303 Protectant". I know they have a bunch of other products now, but the one that says something like "ultimate UV protectant" is the one you want for this.
Old May 2, 2022 | 08:48 PM
Reaper-Z's Avatar
I'm in for this. My ttop pieces are in excellent condition however the middle bar is toast. Faded and spotty. Any ways to deal with that without painting? How would I remove that to paint it?
Old May 4, 2022 | 01:16 AM
The Guz's Avatar
I have this on my channel which will help.
Old May 4, 2022 | 07:55 AM
SAPPER's Avatar
I've used Dieelectric grease for years. Keeps them soft and also from freezing if a car sees winter.
Old May 4, 2022 | 08:31 AM
madmike9396's Avatar
i totally need to do this. thanks for the recommendations guys.
Old Jun 9, 2022 | 04:15 PM
2JAWZ's Avatar
I've just used leather conditioner on mine for years and have never had any issues. They stay soft and hydrated
