Removing a spot weld?
Old Aug 19, 2004 | 11:12 PM
The_Snyper's Avatar
Default Removing a spot weld?
Just bought exhaust tips off of a guy and didn't know they were spot welded on his car. So he hacked the exhaust pipe off... and now I'm stuck with a piece of exhaust pipe inside the tips. Is there any way to break the weld? Keep in mind I don't have a welder or any type of powerful heat source.
Thanks in advance
Old Aug 20, 2004 | 10:30 AM
CanuckSS's Avatar
Eastwood makes a spotweld remover that works really well. All you need is a drill.
It is used mainly for removing spotwelds on body panels but it should work for you as well. You may also be able to find a cheaper version at an autobody supply store or a autoparts store.
Good luck,
Dave
Old Aug 20, 2004 | 10:48 AM
fakeleg.com's Avatar
You might be able to use a cut off wheel / grinder to get it off. Depends on how big the spot is.. best bet is to throw it in a vise and drill it out.
