Door Panel pops off
Old Aug 26, 2004 | 01:26 AM
HitmanLSX's Avatar
Default Door Panel pops off
Ok bought a 99 T/A almost a month ago and everytime I shut the passenger door the panel pops off from the rear part of the door. I tried taking the door panel off and reinstalling it but it keeps doing it and no matter how I put it back on it pops off. Any ideas?
Do I need to get new window seals and see if that helps?
Old Aug 26, 2004 | 02:33 AM
Z28Venom's Avatar
Are the little hooks broken off of the panels?
Old Aug 26, 2004 | 07:15 AM
JackZ28's Avatar
That would explain it, but when you are reinstalling it, are you making sure that all the little hooks go in the holes properly, to prevent the panel from coming off?
Old Aug 26, 2004 | 10:05 AM
HitmanLSX's Avatar
Only one of the hooks was broken off and it was towards the front at the bottom. And yes I'm making sure the hooks go in the holes.
Old Aug 27, 2004 | 09:09 AM
Derek98z's Avatar
So is it still not fixed then? Is the top of the panel hooked on to the top of the door? If you are not super familiar with hanging door panels, it can be tricky at first.
Old Aug 27, 2004 | 09:27 AM
HitmanLSX's Avatar
hmmm after giving it a closer look it appears the inside window seal on the door is bent in one spot... and I know those things never straighten back out so looks like I'm ordering new seals... (might as well do the outside seal while I'm at it)
Old Aug 27, 2004 | 03:11 PM
JackZ28's Avatar
Good luck- hopefully that solves your problem!
Old Aug 27, 2004 | 04:16 PM
HitmanLSX's Avatar
We'll see... looks like I have to replace the entire door came out this morning to a nice big crack in front of the mirror. Turns out the accident was a little worse than the dealer implied and someone had bondo'd the door
