How Do I Put On Vinyl Dammit!
Old Oct 7, 2004 | 09:37 AM
BeeraddSS98's Avatar
Default How Do I Put On Vinyl Dammit!
i got the ram air scoop inlay for the hood. they said they would send me directions and they did'nt so how would i go about applying the vinyl. its a pretty big piece maybe i should'nt take the risk on fu***ng it up?
Old Oct 7, 2004 | 09:48 AM
abadss's Avatar
is it the manta stripe or just the 35th anniversary scoop inlay? if its the inlay, its real easy to do yourself. just get a spray bottle with semi-soapy water and a squeegie. clean your hood up real good, i clayed mine and removed all wax before install. then wet it down good with the spray. then i sprayed the decal as i removed it from the paper, always keeping everything nice and moist. never drenched, but always wet. then just lay it down and position it. work the bubbles out from the center to the edge, the soapy water will also come out when you do this. once you get it good and flat, just leave it alone, the rest of the water and soap will dry from under the decal and all the micorscopic bubbles will go away after a few days. let it sit out in the sun a few days after if you can. anyway hope this helps, it isnt hard, just takes a little patience. also, if you have the manta, take it somewhere and have it done, it is very dififcult. post some pics
Old Oct 7, 2004 | 09:51 AM
thanks man. sounds like ur a pro. hopefully i dont screw it up. ill put on some pics in a couple hours. THANKS again.
Old Oct 7, 2004 | 10:00 AM
01 Red WS6's Avatar
yep soapy water is the trick. I spary the hood and the stripe. Take your time and you should do fine. If you find you need to move it do it while it is still wet and if it starts to get hard to move you can respray but be careful.
Old Oct 7, 2004 | 11:52 AM
Teri9672's Avatar
just did mine last month. I added a small red pinstripe around it. Need a new picture
Soapy water is the key and try to apply it when your hood is not hot.
Old Oct 7, 2004 | 04:30 PM
Hayze's Avatar
Teri nice car
Old Oct 7, 2004 | 07:09 PM
PewterNHRA2001's Avatar
why does there need be soap? also about how much? like 10% soap 90% water?
Old Oct 7, 2004 | 07:23 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Get a nice sized spray bottle, add maybe 4 or 5 drops of soap. You don't need much, just enough to make it slippery so you have some time to move things around incase you have to.
Old Oct 8, 2004 | 08:42 AM
Teri9672's Avatar
Originally Posted by Hayze
Teri nice car
thanks, it was kinda dirty in that picture
Old Oct 8, 2004 | 10:18 AM
01 Red WS6's Avatar
I just put a few drops of soap in the water.
Old Oct 9, 2004 | 04:08 AM
JMBLOWNWS6's Avatar
Soap and water
Old Oct 9, 2004 | 04:20 PM
Bharnz's Avatar
1 teaspoon of baby shampoo to a spray bottle of water.
