About to order Zaino for first time
Old Oct 31, 2004 | 09:03 PM
WAGE_SLAVE's Avatar
Default About to order Zaino for first time
How important is claybar? Do you notice a difference after using it?
Old Oct 31, 2004 | 09:46 PM
OctaneZ28's Avatar
Yes, using the claybar makes a big difference... it takes all the crap and impurities right out of the paint.
It's simple to do too, just grab a spray bottle, put a few drops of car wash in it, and fill it with water, and use that as a lubricant between the claybar and the paint.
Should be able to go over the whole car in about 30 minutes, and you'll be suprised how much junk it'll pull out of the paint.
Old Nov 1, 2004 | 07:41 PM
ls1pwrdss's Avatar
clay bar is defently recomended do not look that stepover
Old Nov 2, 2004 | 03:41 PM
meissenation's Avatar
definitely an important step, but don't get it confused with your every time routine... once you claybar you should be good for atleast a month, if not more depending on the conditions. Here in construction land of Detroit, it's easy to get a LOT of grime on the paint of the car.. but in other cases you might not need to do it as much.
Old Nov 2, 2004 | 03:44 PM
psykoTA's Avatar
I may be claybaring the car tomorrow for the first time as well, How long is the claybar good for? Tills its full of junk? Will it take off touch-up paint from rock chip areas?
Old Nov 2, 2004 | 03:56 PM
ZaneO's Avatar
Just tear off a small piece of clay at a time. Check it frequently for debris. Kneed and fold as necessary. When there are no clean spots left, trash it and start with another small piece.
Old Nov 2, 2004 | 06:19 PM
psykoTA's Avatar
ok, Thanks. What about the touch-up paint?
