Turn signal not working.. HELP
Not sure where this might go, but My driver side turn signal isnt working. It just stays solid everytime its on, it didnt work for a week, then started working again then stopped. The front signal was out so i put a new one in and still not working... can anyone help me, would it be a fuse??? the other side works just fine.
Check your rear bulbs first on the side that stays on. If one of those are out it will cause your fronts to stay on. Don't think it's a fuse. If it was a fuse they would not come on at all. I'm pretty sure about this but I could be wrong. If that dosen't work check your flasher relay. The arm in the relay could have shorted and welded itself to one of the poles in the relay. I had one do this to me in Electronics class one day. Pretty wild of course we use relays with clear housings so we can see them work. Then if none of those work check your wire's make sure none of them are cut. With your mods I'm not going to tell you to check if you got the right bulb. I'm sure you could handle that one.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by az28vance
Pull the bulb and check the socket and make sure that it isn't corroded. My p-side socket was corroded and I had to replace it.
Well when I took the front driver bulb out it had alot of crap, looked like grease... Which might be the cause. Ill check the back bulbs too, but im sure it might have to do with this grease or what ever all over.
