Hid Retrofit.
If anyone has a link to a thread on this forum, please post that. I have tried to search, but nothing.
Thanks, Greg
http://community.webshots.com/album/116863233uyEamc
It shows all the steps to adding projectors to the camaro housing. I'm sure Soulpower used the same methods.
I don't know if it would be worth the $300 to do it. I've seen people add white bulbs to it and it looked nice and white. It's also hard to say if there is a HID bulb available that would fit in the socket. Do you know what bulb size it takes?
and because i get a deal on hi & low projectors, actually i get the C6 unit, and i have to take the projectos out of the unit!! and yes they are new!!mmm no i dont thing it woth spend $300 or more in just a fogligth but thats why i said maybe in the future, for now, i will try to get the white bulbs, then maybe next year i get the HID
ths for all the comments, i have new pics, and im working in the explanation with pics, step by step!!
I went with the BMW E46 projectors because they are probably the best low beams out there and they were under $180 for a pair of used ones. Similar bi-xenon are a maybe $250 or so. That's why most folks get the used ones from late model cars.
Anyway, I'm just waiting for Photobucket to get back on line so I can see your pics. They are usually very reliable.
Is this the low beam?
If so, it looks like the projector is mounted upside down. All the light should be aimed downward on the ground. No light at all should be aimed higher than 3ft in the front. If it did it would blind oncoming drivers. This is what the light pattern should look like with a sharp cutoff line on top.
Here's one of my pics with the projector in the correct orientation. Shield is on the bottom.
When the light goes through the lens on the end it will get flipped. So you want the light to go out the top, over the shield, so that it will be flipped and light up the lower road area. No light (or very little light) should be seen above the windshield area. Stand in front of your car at night about 25 or 50 ft away. Now bend down to where your head would be if you were driving past yourself. Do the lights get in your eye? Or have a friend drive by you in the opposite direction. Can he see OK when passing?
Here are some pics that might help. Note the light beam is labeled #1
"proyects" "proyectors"
today i will fix them, and tonigth will see how it looks!
ths man!
Check out this place for more specifics of proper aiming.
http://faqlight.carpassion.info/hl-aiming.htm
Another thing you can do is add some shields on the sides and top and bottom of the projector to reduce some of that scattered light you are getting. A lot of folks use a real thin sheetmetal. It will give you a more defined and sharper light beam.
Another tip is to take the bulb out and then take a hooked shaped tool and stick it in the bulb hole and bend the shield slightly forward or backward to get the cutoff line sharper. You may also get some nice blue color around the cutoff line.
Here's a pic I whipped up that shows how the lights should be aimed.
Very nice ride and pics of these C6 lights on it, but should get all 4 Xenon, if u see what I mean, anyways looks good!
If you are talking about pulling them out and mounting them into the factory headlight housing, I would not recommend it. They are small, cheap units that do not produce a lot of light. The reflector shape is also designed to push the light to the sides more because it is a fog light. I would only use a high quality projector to put in the headlight housings. They are not expensive, $120-$200 for a pair of good ones.
If you mean leave them in the stock location and use them as low beams, no. There are height restrictions for lowbeams. The factory fog location is way too low. They wouldn't light up much of the road anyway mounted low.
