z06 fuel rail covers
If you did a search on this web board you would find this out.
Here is a link 4 ya.
Answer is here
This is from the search.
Answer is here
Originally Posted by Search Button is My Friend
Here is a link where the guy used the ZO6 FRCs that have the provision for only one fuel line. If you have FRCs with a provision for the return fuel line (2 fuel lines total), then you will have to make 1 fewer cut.
http://www.sysadminzone.com/ta/z06cvrs/
You can also search this site (LS1Tech) for "Fuel Rail Cover" and "FRC" and find some information on this subject.
Here are some P/Ns I found doing such a search.
(Thanks to Kimchee and Rice)
Two Fuel Lines
P/N 12559261 (97-98) LH Fuel Rail Cover
P/N 12556455 (97-98) RH Fuel Rail Cover
One Fuel Line
P/N 12561503 (99-02) LH Fuel Rail Cover
P/N 12561502 (99-02) RH Fuel Rail Cover
Two Fuel Lines
One Fuel Line
'Bird Director
Originally Posted by MrDude_1
12569246 passenger side intake manifold sight shield.
12568998 driver side intake manifold sight shield.
https://ls1tech.com/forums/showthrea...el+rail+covers
They're $32.22 each on gmpartsdirect.
