Cleaned engine bay....finally!!
How hard was it to paint the plastic piece that is around your airbox?
What kind of paint? did you sand it down? etc.....
You can pm me so that this thread stays on topic..............
Now back to your regular posted thread....
As for you lower air box, you need Virgin paint thinner to clean it down use a scuff pad then towel dry with a painters shop towel. Then spray urethane adhisive promoter ,prime light sand base coat clear coat. Or you can single stage it.
All supplies can be found at a local paint store or NAPA.
I used trans star primers and cleaner Dupont Chromabase and 3M clear coat I still had it from the paint job.
Pm me if you need any more help, or have more questions . I think I have step by step pics somewhere.r
I ran it under the carpet all the way up the passanger side then through the firewal where the ECM hard lines come through. Just cut the rubber boot the sealed it back .
Thats why my line just appears under the A/C the runs to the box. Electric wire ran the same way grounde the WOT switch with fuel pressure. Took about an hour to do it.
that is good stuff. Everytime i clean and put a fresh layer of zaino on her she feels faster... (makes you feel great!) its amazing how the dirt after driving in the rain makes the car feel slow, and depressing hehehe..-drv
were did you get the Foamy Engine Brite and the CD-2 Engine Detailer?
I don't know if they quit making it or something. I hope not becasue it was great. I should have bought a bunch of them up.
