Contest-winning detailer tricks?
And then there's Todd...
However, what are some of the tips and tricks the contest winners use? What are the spots the average enthusiast might not think of cleaning/polishing that make the car stand out?
Some examples I've seen/heard:
- Windows (often overlooked)
- Cleaning the wheel wells
- Door sills
- Interior trim
-Mike
Area above exhaust tips
Door jambs
Inner wheel
All the little nooks and crannies
Clean the inside of the exhaust tips and inside the door mirror cowlings. And then there is the whole underside cleaning thing - polish the drive shaft, coat the wheel wells with rubber/vinyl protector, clean the inside of the wheels, polish the exhaust pipes/muffler, etc., etc., etc.
Glass - Not just the outside but the inside too!
Jambs - Not just the doors, dont forget the trunk, hood, hood cowling etc.
Trim - Shine it up with some type of protectant
Rims - The inside needs cleaning too, not just the outside
Wheel Wells - At the very least, degrease 'em. The vinyl/rubber protectant thing isnt for everyone
Exhaust tips - Inside and out for @ least 6" beyond the exhaust tip (Depends on show, and what setup you've got - being thats what most judges are gonna be able to see)
Interior - Shine it up w/ some protectant. Dont forget to vacuum UNDER your seats, inbetween the seat(s) and the center console as well as any place else you'd think a dust bunny would hide
Using Z6 to wipe it down actually makes it kinda shiny. Easy to do.
Insides of wheels and wheel wells are often not done too.
My wheels are easy to clean, I shoot some Eagle One A2Z Wheel/Tire Cleaner on them, wait 60 seconds, and hose them off.
For the wheel wells, well, since I race my car alot, often the first thing I have to do is scrub all the rubber out. I've found the best tool for this is my fingers...yes, ouch, but you get used to it, hehe. After that I hose them down and scrub them with a brush quick, then when they're dry I drench them in Armor All. No, it doesn't last, but it makes them look nice for a show.
In my experience with cleaning the engine bay, the method that has worked best for me is (cool engine bay) spray Simple Green Automotive on everything not black, wait 5 minutes, and hose the entire engine bay down, light water pressure. Then once it's dry (it takes 15-60 minutes depending on the weather) use Armor All or any tire shine or plastic shine to dress up the airbox, hoses, plastics, etc... the black stuff.
Get a few small detailing brushes for wiping dust out of the creases and crevices of trim, weather stripping, interior screws, panels.... you name it. Those brushes come in very handy!
Simple Green Automotive also works well for cleaning up exhaust and the undercarriage.
-Mike
and thank you !Like OctaneZ28 mentioned...
One simple thing that I found out is using a soft 1 inch wide paint brush and dusting the cracks, under wires etc. with it in the engine compartment.
Around the below area... it is a huge help, a towel just can not fit in those tiny cracks\areas under and around the braces etc.. Then if you get crazy follow behind the dusting with a vacuum cleaner.
