clay bar residue question
Old Apr 14, 2005 | 06:47 AM
02transhawk's Avatar
how about using dawn in the wash, then a cleaner wax should do the trick.
Old Apr 17, 2005 | 07:43 PM
ssPetess's Avatar
Originally Posted by ssPetess
I just to talked to Sal, he said you never have to wash your car with Dawn, you can Z1 then Z2 right over the existing coats. He also told me that the Z2 or Z5 should take the residue off. We'll see tonight...
Z2 took the residue off, car's looking better that ever...
Old Apr 17, 2005 | 07:49 PM
Frontman's Avatar
I did dawn, and cleaner wax. Still have the f-ing residue!! I'm ordering the zaino stuff tonight. I was looking to make the jump anyway, now i just have an excuse.
Old Apr 17, 2005 | 09:00 PM
ssPetess's Avatar
I put on a thick layer of Z2 and rubbed it in pretty good. I let it sit over night then wiped it off with a microfiber towel. Was a bitch to get off but it did take it all off. I then Z6ed it then Z1, let it dry and another light coat of Z2. Let it sit over night again, then Z6 one more time. Looks great...
I just ordered some Z2 pro and Z8, can't wait to try that stuff, I heard it's unbelievable... I love Zaino products, best stuff I've ever used. I ordered ZFX too, Sal recommended it so I'd thought I'd give it a try...
Old Apr 17, 2005 | 09:58 PM
777's Avatar
777
Originally Posted by wrath22
toothpaste?!?!?!?!?!?!? no frigin way. unless you leave the clay residue there for a while the clay bar itself will remove it. if the left over has been left on for a while and has been exposed to sun where it has become hard. make sure the car is in the shade and cool as well as clean. use a spot remover that is just for cars. spotter works well, use a small amount and let the chemical do the job try not to press too hard. the spotter will remove any type of wax that is there. so you will have to re-wax that area. stay away from any thing that is not for cars such as dawn and toothpaste. please don't listen to those "ideas" also finaly inspection by meguires works well too with a SOFT detail brush. if you don't won't to try any of those good old fashion warm water will losen it up not boiling but warm. good luck man.
dawn is perfectly fine to use on cars to get old wax off...as for toothpaste...no...that is like wet sanding your car...i wouldn't use toothpaste on anything...
Old Jun 7, 2005 | 07:08 PM
ozzykicks2002's Avatar
toothpaste is good for 2 things brushing your teeth with and it have the random zit on your face, apply some toothpaste on it and run it in. when you wake up it will be gone no joke.
