Need Pics: Cars w/ the SLP Eibach Springs
Originally Posted by burnout04
What grille is it that a few cars on this post are using? It's the grille that looks like you just ripped out the plastic part of your bumper, except with the insert it gives you a mesh grille and covers up all the holes and crap
Shay
Originally Posted by 02transhawk
Cutting the springs is not a good idea IMHO. Yes, the car gets a better stance, but you loose performance from the spring and also ride stability over bumps and stuff. Be very careful if you do this. I would not reccommend doing this for a daily driver.
Does cutting 1/2 a loop off a coil change the spring to an unsafe produce? No. Have the rates of the spring changed? Maybe by ever so much, but not enough to make the spring totally dangerous.
This is a time tested practice that has and will continue to be praticed by garage warriors to all out racers. Is it a task to be taken lighty, heck no, but it certainly does not deserve to be kyboshed. Just my 2 cents.
Teri you copy cat
Sold The Fun Stuff :(
Thanks for the pics. Xsta, Teri, and Ken's cars all look especially nice. As I'm on a budget, I went for the budget minded setup. I had some BMR rear springs from a previous setup, so I bought some front springs to go with those and I'm going to give this a shot. If it doesn't sit well, I'll put the stock rear springs in with the isolator removed for a more raked look, then start saving up for some four corner coilovers so I wont have to deal with all of this again.
FYI, those of you with 2000+ model SS and Firehawks, you have the Bilstein Ultra Performance Suspension, which did not come with the SLP/eibachs. They have different spring rates and the SLP/eibachs are black in color, where as the Bilsten Ultra Performance springs are blue.
