Removing LAst of the Breed Badge
Old May 23, 2005 | 10:12 AM
RGV_Z28's Avatar
Default Removing LAst of the Breed Badge
Well I had a minor mishap with my car this weekend, and the fender broke. Getting a new one. How would I go about taking the bagde off?? does it just peel off?? Heatgun?? Thanks guys.
-John
Old May 23, 2005 | 10:16 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I've not looked at one up close, but to get the emblems off of my car, dental floss worked like a champ. Fishing line would work too.
Old May 23, 2005 | 10:34 AM
01 Red WS6's Avatar
heat it up and peel it off. When I bought my truck the dealer put the same kind of badge on my truck and it peeled right off and was still good. I would think it should work for the LOB Badge too
Old May 23, 2005 | 07:21 PM
sprung_monkey's Avatar
just make sure when you do get it off use the special badge/emblem glue.....my friend acctually used super glue when his ws6 badge came off yeah you can guess how it turned
Old May 23, 2005 | 07:29 PM
94formulabird's Avatar
Heat it up with a hairdryer...then take some fishing line and run it back and forth behind the badge..after you get enough off..you can just peel it off, just becareful not to break it in half
Old May 23, 2005 | 07:34 PM
Andros's Avatar
When you do this wear gloves or something to protect your hands. It hurts if you dont
Old May 23, 2005 | 10:51 PM
01 Red WS6's Avatar
The badge isn't a hard plastic or metal, Just FYI It is kind of like the domed decals that fill in the letters on the back bumpers and panels on our cars
Old Aug 2, 2006 | 05:20 PM
ws6man's Avatar
I have been looking for theses badges does anyone know wehre to get them?
Old Aug 2, 2006 | 05:26 PM
Scotty-Z's Avatar
Heat it up a bit and use some floss or fishing string/wire to work your way behind it. Just simply floss behind it, don't attempt to peel/bend it off as you do. I've heard that those LOTB badges can separate or break upon removal. So just floss behind it, let it fall off into your hands as you finish, clean up the back, and you're ready to go.
Old Aug 2, 2006 | 05:45 PM
EvilBLK02TA's Avatar
http://www.carr.org/~gripper/partshtml/gmfbody.html
Go here, expensive but they look good, got myself a set already
Old Aug 2, 2006 | 08:08 PM
Firehawk526's Avatar
Yes, the adhesive should lift off relatively easily, but use the aforementioned techniques. I just relocated one of the small ones from one area to another w/no issues.
Old Aug 2, 2006 | 08:45 PM
2000blackta's Avatar
Always worked for me.
