My door is coming apart!
Old May 25, 2005 | 01:56 AM
Darkspoon's Avatar
Default My door is coming apart!
The outside of my passenger door is like..coming off!? when its closed, the top part of the door sticks out bout 2-3mm...and i can pull it back farther and see like the epoxy or whatever that held it together is off....whats the fix to this?
Old May 25, 2005 | 05:53 AM
DopeFedZ's Avatar
Take it to the dealer and see if they can do something about it.
Old May 25, 2005 | 06:48 AM
contraststriker's Avatar
what's your vehicle
Old May 25, 2005 | 08:36 AM
Darkspoon's Avatar
Originally Posted by contraststriker
what's your vehicle
oops, guess it woulda been better to mention that...its a white '02 z28 M6.
Old May 25, 2005 | 09:41 AM
jksz71's Avatar
Go to a dealer or a competent body shop and have them clean and reglue the door skin to the frame. This is a common problem that is easily repaired. Hell if an Fbody is ever rearended hard enough the actual door skins pop off during the accident.
Old May 25, 2005 | 12:53 PM
VIP1's Avatar
Copy & Paste Moderator
If its still under warranty, the dealership should fix this for free.
Old May 25, 2005 | 01:03 PM
01 Red WS6's Avatar
The dealer can fix it. I've seen it happen before
Old May 25, 2005 | 08:02 PM
evilbadz's Avatar
mine is doing this too
How much do you guys think it would cost to get this fixed?
Old May 25, 2005 | 08:23 PM
C.J.'s Avatar
just take it to a body shop, my last z28 had the problem. They fixed my passenger door for like $30 or something, not bad. And its from slamming the doors is what they told me, sounds like a good reason seeing as that it was my passenger door b/c i never slam my own doors lol
Old May 25, 2005 | 08:28 PM
Bawls's Avatar
I've had the same problem on both of my fbody's. First 94 z28, and now my 94 formula. What I used was, JB Weld. Works like a charm, it'll never peal back again. Sand it down after it dries, repaint it, and you're good to go. JB weld costs what, $4?
Old May 26, 2005 | 11:13 AM
john shea's Avatar
Wow my daughters 93 camaro has this problem. I had no
idea it could happen on such a late model.
Old May 26, 2005 | 04:08 PM
Corey R.'s Avatar
mine too, i jsut used JB weld, never had an issue since, that was 5 years ago too.
Old May 26, 2005 | 04:13 PM
00Z28 Camaro's Avatar
funny , I've only seen this on the passenger door
