applying claybar questions
2. clay the car using meguires quick detailer or something similar. clay the car in small sections, use a micro fiber towel to dry the area you just clayed. yes, you do want to turn the clay periodically, in fact just start pulling it apart (kneeding) and reshape it often, kinda like silly putty. claying will take a good hour/ hour & half. DO NOT DROP THE CLAY ON THE GROUND because it will pick up small pebbles, sand, dirt, etc.
3. make sure you put down some type of wax/ polish afterwards
4. enjoy the silky smooth shine
This is the order in which you do it- Good Wash, Clay bar every part of your car (you don't have to rub the crap out of it, just a nice thurough slide, and MAKE SURE you keep the area lubed/wet.) then wax to seal the car.
When claybaring work one section at a time i.e- spray one door, claybar, spray one quarter panel, claybar etc. Stuff is awesome and leaves yous finish feeling like silk.
