Antenna Mod
Here is a write-up on that:
http://www.blackcamaro.com/antenna.htm
I remember reading a while back that some members cut their solid-mast antennas and covered the end with a small black cap.
I did a quick search and found some threads.
In this thread, n2oblkz talks about a short antenna he bought
https://ls1tech.com/forums/showthrea...ht=cut+antenna
In this thread, jammon46 says he cut his antenna:
In this thread more people talk about cuttin the antenna:
If you do more searching (like I just did for this post), you'll find more info on power antenna and shorter antennas.
True concept but that would be for one specific frequency correct? I think most people listen to more than one station broadcasting on different frequencies so if you get close to half you should be fine. Personally mine is cut down way shorter than any pictured here and honestly my reception hasn't suffered from it. Go figure as the physics behind it state the reception should suck now.
What happens in essence is that when you cut your dipole antenna in half is yes it reduces it to a 1/4 lambda, but it uses the metal in your car to make an "image" of a 1/2 lambda dipole antenna. Still doesn't have as much gain as a full length antenna. But what do I care. My Stereo plays MP3's, I never listen to the radio.
