Blue T/A Shifter Lights
Old Jun 20, 2005 | 08:44 PM
InfiniteReality's Avatar
Default Blue T/A Shifter Lights
Well, since I recently found out my shifter lights are suppose to light up, I had one LAST item to turn to blue. Soooo, it's been done! Used an 02 SS (what auction stated) console. I only swapped out the shifter part and kept my original console in place. Mainly due to the hawk emblem on the console. I used 8, 3mm, 7000mcd LEDs to light it up. 1 LED per letter on the shifter and gave the OD 2 LEDs. I wanted to use 8 of them to keep the wiring down to a min, plus didn't have to use any resistors as well. I also choose to use 3mm versus 5mm due to the size, my 3mm were brighter (5K vs 7K) and lower profile so they didn't interfere with anything (but wouldn't even if they did stick up some). I first grinded the LED heads flat to dispurse the light better. Then just marked where they go, drilled the holes, superglued the LEDs in place and soldered. Took about 1 hour start to finish.
Another note is the 98, 99 and 00-02 consoles differ. not sure how, but I read this.
Old Jun 20, 2005 | 10:45 PM
OneMeanZ's Avatar
Hvae you made the gauge cluster turn blue? If so I must see pics
Old Jun 20, 2005 | 11:15 PM
Brian2006's Avatar
Why did you need 8? Wouldn't it be easier to just use the 1 led and not go into as much trouble? Seems to me like that would be an annoyance if it's that bright....but hey what do i know.
Old Jun 21, 2005 | 02:30 AM
Black98Z28's Avatar
to me it looks a little TOO bright...i notice the blue reflecting off the shift **** LOL thats really bright...why not use 3-4?
Old Jun 21, 2005 | 07:19 AM
Yep you are correct, they're too bright. Compared to all my other gauges, they're twice as bright! Reason I choose to use 8 and not 4 is because LEDs are directional. Even with grinding the heads flat, up close to an object they still emit a focused beam of light. This way each letter gets its own LED so their will be no hot spots. Making them dimmer is easy as putting a resistor and that'll be done tonight after dark so I can test different size ones to get the right brightness this time..
Old Jun 21, 2005 | 11:02 AM
Yep whole dash blue. Everything.
Old Jun 21, 2005 | 12:19 PM
Camaro4Life's Avatar
wow, looks good man!
Old Jun 30, 2005 | 01:13 PM
King James's Avatar
Did you figure out what resistor is needed?
Old Jun 30, 2005 | 01:52 PM
hpjunky98's Avatar
do you sell kits at all? i know somone does on this board for camaros
Old Jul 1, 2005 | 07:55 AM
Nope, sorry no kits. THOUGH if he has a kit for the camaro, since you'd have a camaro console it's feasible... I used individual LEDs for mine as I didn think only one would light it up enough. If it would, it wouldn't be even. I just made that assumption though.
Hell, I did know what size I used but my mind's blank. I "THINK" it was 120ohm. I actually have the rest sitting on my desk at home. Send me a PM to remind me and I'll tell you tonight
Old Jul 1, 2005 | 09:11 AM
do0dfromcali's Avatar
Looks good
