new zaino swirl remover
#41
So from what I'm gathering, the new swirl remover is part of the ENTIRE process -- meaning since we just went thru the whole Zaino kit process from the beginning (dawn wash, claybar, wash, Z2, Z5, Z6 etc., etc.) that the swirl remover would be used the NEXT time we want to go thru the entire Zaino process. In other words....the swirl remover would remove all of the Zaino that's on the car now?
Your car looks great, and IMO the hard effort put into the original Zaino'ing of a car is well worth it. Especially on black cars.
#42
People tend to over exaggerate the Zaino process. Once the surface is properly prepped (which should be done before using ANY product), you only need one coat of Z2 Pro or Z5. Anything more is extra that you have chosen to do.
#43
Zane: You tried the Z-PC yet?
I just bought it out of sheer curiosity and nothing else, but I haven't had a chance to give it a whirl. I was thinking dual action with a white LC pad would probably be a good combo for it. I'd like to avoid wasting it with experimenting as much as possible because it ain't cheap.
#45
Originally Posted by 2000blackta
alright, 5 hours later we're done. now keep in mind that this car was pretty f'd up. i think that it came out unbelievable considering that this was all by hand. procedure was wash, claybar, wash, swirl remover, one coat of z5, and hit with quick detailer.
Wish I had it for this project - it probably would have come out better.
Before heavy duty cutter, clay bar, ScratchX...(yes, the date is off on the camera)
Window broken out, used highly flammable remover to get the duct tape goo off the passenger side
I wanted to get the entire car because it was in such bad shape before spending 6 hours on it
There is no help on the rear plastic bumper. Its toast but then again...the car is a POS anyway
Once my Zaino cutter comes in I'll redo it and see what I get - maybe little difference (there are no hairlines in it now) but its worth a shot to practice on.
#46
Originally Posted by ZaneO
The Z-PC will remove any wax/sealant on the surface. It is meant to be a prep product to remove defects such as swirls and light scratches. Use it when it's needed, don't if it's not.
Help me out.....thanks
#48
Originally Posted by OneMeanZ
ZaneO, is the Z2 Pro and Z5 polishes or waxes. Or both? I'm confused here. If you used the Z2 do you have ot put wax on to seal it or does the Z2 Pro seal it already?
The only real polish in Zaino's line for paint is the abrasive Z-PC. I don't know why they opted to call the two sealants polishes...they just did.
