HELP! Complete Newb To Detailing Car
Remove the nozzle off of the hose you're using so the water will flow freely out. Then take the hose and take it to the top of the car, angle the hose a little bit so you're letting the water flow with the lines of the body. You want the water flowing freely out of the hose, onto the top of the car, and down the sides. The water when it has unrestricted flow like that actually sheets all the water together off the car. When you get the hang of this, you can practically dry the entire car just by using the hose correctly.
I've been doing this for awhile and I've gotten good enough at this that by the time I'm done sheeting the water off, all I have to dry are the t-tops, windows, and under the spoiler and then the cracks and stuff... the body panels all air dry perfectly doing it this way and don't leave waterspots.
Ive never used some of this stuff until yesterday because of reading this thread, but i have a question about the polish, i dont have a buffer so i had to do it by hand. Are you suppose to keep rubbing it in until its gone? I kept getting some left over cuz it was getting dry, so id use a microfiber cloth to wipe the excess off.
Please advise
thanks!
Mike
EDIT: Oh yea another tip to try with polish, try using a terry cloth towel to apply it, instead of a foam applicator, the terry cloth is alittle more aggresive in removing dead paint, oxidation, swirls, etc. than the foam is.
