Zaino Questions...
Old Jun 26, 2005 | 03:41 PM
OneMeanZ's Avatar
Default Zaino Questions...
My car is in need of some appearance care bad. I saw a thread about the new Zaino Swirl Remover and my car really needs this. But what else goes along with using Zaino.
I've seen people throw around stuff like Z5, etc. I have no idea what I need to get the polish, wax, etc. I'll be claybarring it also, so someone please tell me what I need to order. Thanks.
Old Jun 26, 2005 | 06:21 PM
mason71's Avatar
Get Z1, ZPC, Z2, Z6, and Z8. Read the information that Zaino has on their site, (product info, tips and tricks). Your paint will never be the same. Zaino is Awesome. Good Luck!
Old Jun 26, 2005 | 06:36 PM
NBM7278's Avatar
If you use ZFX, I don't think you need Z1. The ZFX helps the polishes cure much faster. Helped me out a few times. Like Mason said, all info is on their site.
Old Jun 26, 2005 | 07:00 PM
2000blackta's Avatar
yep you're right. if you use the ZFX, you don't need Z1.
Old Jun 26, 2005 | 07:30 PM
OneMeanZ's Avatar
Would I use the Swirl Remover before that first or after that
Old Jun 26, 2005 | 09:16 PM
2K2WS6TA's Avatar
The swirl remover first, then your Z2 (Z5 if you have a dark car) with the ZFX mixed in
Old Jun 26, 2005 | 11:11 PM
NBM7278's Avatar
Once you start, take your time and do all the steps correctly. Make sure not to settle for "good" results. You'll love the final results, even though you may have to wipe some sweat off your newly polished car. When your done, post some pics and show it off.
Old Jun 27, 2005 | 10:05 AM
yep. but i'll actually do a coat of Z5 and then one of Z2.
Old Jun 27, 2005 | 10:30 AM
ZaneO's Avatar
Don't get carried away with trying to do all the coats of this and all the layers of that...
Since you've decided to use Zaino, do a process similar to this:
Wash w/ any car wash soap
Claybar - Zaino Z18, Clay Magic, etc.
Wash again
Remove defects - Z-PC Fusion
Apply Zaino Z2 Pro with ZFX (1 oz. needs 4 drops of ZFX and will do 3 full coats on your car)
Do a final wipedown QD with Z6 or Z8
Your basic shopping list should consist of:
Claybar
Z-PC Fusion
ZFX
Z2 Pro
Z6 quick detailer
Optional products (aren't *necessary* for the system to work, but I highly recommend them):
Z7 car wash
Z8 spray sealant
Z16 tire dressing
Old Jun 27, 2005 | 05:20 PM
OneMeanZ's Avatar
ZaneO, thanks a lot for that post man. Cleared a lot of **** up.
