front grill
front grill
how do u get to the 2 screws in the grill..all that foam is in the way..im not sure how to take it off..and i dont want to break it cuz im tryin to reuse it..thanks
mike
mike
Remove the bumper cover and you'll be able to get it off and save all the clips. I started to do it this way, but gave up and pulled it off. The grille is still in good shape, but I don't have the hardware to remount it (planning on going with a SLP SS grille anyway).
How are you planning on reusing it...painting it body color? I've got a friend with a Ceyenne V6 which she painted the grille body color and it looks great! If you want to put it back on, you'll have to take off the bumper cover anyway, so do it all at one time if possible. Either way, to keep the mounting hardware, and to ensure the grille isn't damaged, I'd pull the whole cover off even if you have to do it twice.
Here's a couple guides:
https://ls1tech.com/forums/drag-racing-tech/318997-anyone-have-write-up-how-remove-front-bumper-support.html
http://www.slponline.com/inst/10668R.pdf
ya we are doin an experiment with it sorta..painting it gloss black after cuting and sanding the ridges out of it, so instead of havine 6 holes it will have 2 large ones on the sides of the plate....thanks for the info..
