Convert. top switch for a E-cutout?
Old Jul 25, 2005 | 10:24 PM
Huntr1117's Avatar
Default Convert. top switch for a E-cutout?
I've read that some of you have used the convert. top switch for your electric cutout. I was wondering how hard it was to wire? What's the part# on it, and how much does it cost? I was also wondering where I can mount it? I have my traction control switch like this.... http://img.photobucket.com/albums/v...17/000_0463.jpg I've seen some cars that have the convert. switch and the tcs switch mounted the same way next to each other. Where can I get that kind of mounting plate?
Old Jul 26, 2005 | 01:30 AM
NOIR's Avatar
good question.
i personally plan on mounting my e-cutout in my ashtray so its hidden away.
and probably just picking up a switch from auto zone. but not sure how to mount it so it looks nice in the tray, dont know what material to use to fill in the space and hold the switch in place.
im under the impression they make a bezel where the tcs button is that holds 2 switches, for verts or something. gmpartsdirect.com would have it, if it exists.
Old Jul 26, 2005 | 02:56 PM
Toonz's Avatar
It's easy to do.... and the wiring is easy. I'm looking for the write-up I did of it when I did it. I have the vert switch as my electric cutout, and the TCS switch as my line lock.
Old Jul 26, 2005 | 03:49 PM
Toonz's Avatar
Ok, I couldn't find the nice writeup I did, but here's a post I made back in 2003. LOL Instead of buying the wiring harness for it, I bought a $0.50 8-Pin connector at radio shack and made my own. I still have to dig up the part numbers for the switches.
I don't have any pics of the homemade harness though, never got around to taking the switch plate back off and getting them. Here's what outcome looks like.
"Just in case someone else wants to install the switch and use it for an electric cutout here is some info I got for the pinout of the switch....
(This assumes you have the switch harness... I made my own with a nylon connector from radio shack and saved $45 or so)
Pretend that you already have a convertible top harness installed in the car, and the plug is just sitting there without the switch connected. Take the connector and orient it so that the locking tab is on top, and the plug is facing you. With this pictured in your mind, this is the connections of that plug:
TAB
H G F E
A B C D
H = Ground
G = Empty/Missing (not used)
F = Power (12v)
E = Up (+) Cutout (open)
A = Down (-) Cutout (close)
B = Lamp (+)
C = Lamp (-)
D = Ground
There are two grounds. In order for the switch to reverse the polarities for the up/down (+/-) to open and close the cutout, connector "H" and "D" have to be jumped together to the ground on the vehicle.
Holding the actual switch in your hand, it will be upside down so the locking tab part will be oriented on top. This should help you figure out what pin is what on the switch, use pin "G" as a guide.
This makes fairly good sense once you have the swtich in hand. After spending the 15 minutes making the wiring harness the install was quick and easy. I'll get some pics of it sometime soon."
Old Jul 26, 2005 | 11:17 PM
Huntr1117's Avatar
If you can get the part#'s for everything as well as some pics let me know.
Old Jul 26, 2005 | 11:36 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
From GM Parts Direct....
Conv. Top Switch #10195580
TCS Switch #10273882
Bezel #10280510
Camaro 1993-2002 Conv. 1997-1999
Pontiac 1993-2002
For the trim bezel, only one part number was listed. It broke it down as I've typed it out, but there isn't a way to specify that info when ordering online.
I hope this helps
Old Jul 27, 2005 | 02:06 AM
Toonz's Avatar
Is that the part number for the double bezel? I know they make a bezel that only has ono hole in it (for the TCS switch). Anyways, the piece I bought from Radio Shack looks like this, except with 8 pins instead of 6.
Old Jul 27, 2005 | 08:10 AM
y2k_ta's Avatar
'Bird Director
The diagram given showed the trim bezel with the TCS opening only, but as I pointed out both are listed (for the Camaro only). They only gave one part number (for all versions listed), so I'm not sure how you'd specify what version you need when ordering.
I haven't done a mod like this myself, or I would of had the part numbers off the stuff I bought. I just wanted to help out.
Old Jul 27, 2005 | 09:00 AM
Toonz's Avatar
That's cool... I don't have the part numbers handy either since my car is halfway around the world right now.
Old Jul 27, 2005 | 09:13 AM
LS69TA's Avatar
This is just what I've been looking for. I'm still trying to track down a used vert/tcs switch panel to use.
Old Jul 27, 2005 | 10:54 AM
3pnt4maro's Avatar
check on ebay.they have one every now and then..
Old Jul 27, 2005 | 11:58 AM
y2k_ta's Avatar
'Bird Director
That puts it in perspective. You're very appreciated here.
I looked on Year One and Classic Industries, but didn't find it there either. I was hoping for a pic and an accompanying part number to clear this up
Old Jul 27, 2005 | 06:24 PM
ls2 bait's Avatar
just out of curiousity do u have to hold the buttons the entire time or is it a 1 push deal? i wanted to used this for my cutout and my slp fan switch but the fan switch i dont want to hold the entire time. also what cutout do u have?? i have the qtp and it has a lot of wires out back of it.
Old Jul 27, 2005 | 08:49 PM
Brian2001SS's Avatar
Great post for me as well. I am in the process of getting together info for the dual vert bezzel for my ss. I want to use the tcs switch for the cutout. I think it will give me a clean look having the vert switch right next to it.
Old Jul 28, 2005 | 12:58 AM
Toonz's Avatar
I have the QTP cutout. There are a lot of wires coming off of it, but the little wire pinout I have above works perfectly.
You will need to use the Vert Switch for the cutout because it's a two way togel with a neutral spot in the middle. The switch supports positive and negative voltages that are needed to open/close the cutout. (I.E. Push one way, it opens the cutout, push the other way it closes it.) You do have to hold the switch down to open/close it completely (about 3-4 seconds) just like the orginal switch that comes with the cutout.
The TCS switch is a single action switch so it won't work for the cutout. It works good for a line lock, because as long as you hold the switch, the circuit is completed and the line lock is engaged. As soon as you lift off, the circuit is broken and the line lock disengages.
Hope that makes a little sense.
Old Jul 28, 2005 | 08:06 AM
ls2 bait's Avatar
does anyone know if gm makes a switch that would fit in there that could operate the slp fan switch? it has high/ low and nuetral. just like the cutout however i dont want to hold it for the fans. i dont mind for the cutout.
Old Jul 28, 2005 | 09:32 PM
ls2 bait's Avatar
ttt for the fan switch.
Old Aug 5, 2005 | 06:02 PM
LS69TA's Avatar
Thanks for your inquiry to www.gmpartsdirect.com.
Here are your part numbers you requested.
10411285 front floor console accessory trim plate, for convertible, and with traction control switch options. does not include switches.
The other part # listed above was just for the tcs panel. This one is for the vert. and tcs switches.
Old Aug 7, 2005 | 01:02 AM
The PAT WS6's Avatar
so cant you just buy the package that qtp offers that comes with the toggle switch and all and that will work fine if your goin to mount it in you ash tray?
Old Aug 7, 2005 | 10:54 PM
Huntr1117's Avatar
So if I get the vert. switch will it come with a wiring harness that I can splice into or not?
