Whisper Headlight mod question.
Old Aug 9, 2005 | 05:27 PM
vMaster0fPuppets's Avatar
Default Whisper Headlight mod question.
I... ahh... well am impatiant so I broke the headlight. I superglued it together you guys think thatll be ok???
Also how I have to take the gray silicone out before I put new in before I put it back together??
I heard that silicone wont stick to silicone.
Old Aug 9, 2005 | 05:46 PM
Brian2006's Avatar
What I did with mine is I put the headlight in the oven for 20 minutes, and then with the silicone warm I took a flathead screwdriver and took the lens off and the scraped all the old silicone off with that screwdriver. Painted it and then re-siliconed. I don't know about superglue working, it sounds to me that water would somehow leak in there.
Just whatever you do make sure you use a lot of adhesive that way it's impossible for water to seap through.
The end result is always worth it:
Old Aug 9, 2005 | 05:49 PM
Reject's Avatar
purty car Brian
Brian2006's Avatar
Originally Posted by sycotic_reject
purty car Brian
why thank you
Old Aug 9, 2005 | 06:28 PM
ok but do I hjave to remove the silicone cause it's not coming off very easily...
Old Aug 10, 2005 | 07:12 PM
Mr. Trick's Avatar
What temp does the oven have to be set at, do you have to pre heat it or anything?
Old Aug 10, 2005 | 07:19 PM
Ling_650vette's Avatar
Instructions - http://www.cardomain.com/ride/224386/2
Preheat to 200*F then bake the lights for 20 min.
Old Aug 10, 2005 | 08:53 PM
ok well do you HAVE to remove the old silicone??
Old Aug 10, 2005 | 11:49 PM
Brian2006's Avatar
yes you do and just take a flathead screwdriver and scrape it all out. It's pretty easy.
Old Aug 11, 2005 | 06:35 PM
I'd probably use a butter knife instead than a flathead. Probably a little easier to control, and its not as hard edged as a flathead but if you're careful a flathead would probably work well.
Old Aug 11, 2005 | 06:40 PM
Brian2006's Avatar
Either or...I just wouldn't leave the old silicone mess in there.
Old Aug 11, 2005 | 06:47 PM
XxXTransAmXxX's Avatar
Yes, not that I have a Camaro, but anything you will be "re-sealing, or glueing" you want the surface to be smooth, and clean for the adhesive to work it's best! Good luck! Brian nice lookin Camaro though buddy...
Old Aug 11, 2005 | 06:55 PM
I knew what you were sayin. Im sure some people out there will get over zealous w/ a flathead and end up scratchin or breakin something, thats the only reason I'd recommend something else first. But both of 'em work.
