Hood Heat Extractors ... do they work well?
I'm looking at hoods with heat extractors.... i.e., SLP HO, Mecham, Suncoast. Do heat extractors bring the engine temps down enough to warrant spending the money on a new hood? I want to keep it low-profile, but with heat extractors.
Would I be better off just having my current hood fitted with heat extractors at a good custom body shop?
you mean louvers? I'm sure it really doesn't do that much. However i have seen a Ultra-Z like hood that had a huge array of gigantic heat extracters hehind the intake.
Overall i'm thinking a cowl hood would offer pretty good cooling. Better than an SS hood at least.
R.I.P. November 11, 2007
I have several hood scoop molds, one beening the Mecham
Style at my shop . We are about ready to sell the hood scoop only so anyone wanting one let me know. Rex
I had a custom 4 port heat extractor ram air hood done by US exotics. Though mainly for looks and the "bling" factor I do literally see heat radiating out of them at a stoplight. If you would like to see..check the (ccw 19x13 doable?) thread in the wheels/tires section. I definitely wouldn't call it a "performance upgrade" thought, just my .02
I'm hoping to get a little more life out of this new motor with 'heat extractors' in the hood. This Florida heat index is extremely high for a good part of the year. It makes sense to me that it can eliminate (or at least help with) high engine temperatures and should create good airflow for the motor in traffic jams and redlight-to-redlight traffic around town.
I sorta' want to keep my stock Trans Am hood and keep the car sleeper-looking.
REX, I see you're a sponsor here. Do you ship those moldings in a basic black color? It's probably too much to keep up with all the color variations out there, however, a basic black might be possible????
Originally Posted by rex orr
Hello We are building our first heat extractor hood scoop today we can build them in eithe black or white. It will be a bond on type of scoop. We have many differnt items that are not listed or mentioned on our web site. I really do need to take the time to update it. Sorry about that Rex
8 sec potential, 12 sec slip
I don't think it will prolong the life of your engine any by having a heat extractor hood. I know my Mecham hood does let out some heat from the engine bay, but the engine itself will not benefit at all- it is probably still as hot as if it were under a stock hood. $.02
Get a Mecham hood. It has 4 heat extractors to start with, then if you wait a while, the sides of the hood begin cracking, allowing more heat to escape!
Rex, are you saying you will make the entire hood with some heat extractors like Mecham's for a TA? At least you guys make quality stuff, not like Mecham.
![Thumbsdown](https://ls1tech.com/forums/images/smilies2/thumbsdown.gif)
I was thinkiing maybe cutting the holes in the hood myself and buying some Mecham-style, black, carbon-fiber extractors to mount in my stock Trans Am hood ... mainly just to allow heat to escape on the hottest of summer days ... don't want to buy another hood. I like the stocker a lot and want to keep my car as sleeper-looking as possible.
It would be somewhat for looks, but, mostly for driving in traffic jams.
Originally Posted by 99FormulaM6
elaborate...
Thanks,
Jeff
I've done yarn testing at speed.
The front 1/3 of the hood (on LT1 cars) appears to be the only area that is low pressure. Many of the hoods you see have "heat extractors" more towards the rear and that's where there is high pressure. Any hole in that area is going to cause air to rush under the hood. I know it sounds counter intuitive but we need to stop thinking about airflow, and think more about air pressure in these scenarios. Where there is high pressure is at the back half of the hood, especially at the windshield. Any opening in these areas will cause air to rush under the hood.
Putting a small ridge (1/2 inch) at the front of an opening can help create low pressure and let the air escape. You might consider this when designing a heat extraction vent.
Concerning heat leaving the vents at a stop light, this definitely works,heat rises, there is no difference in pressure, so it's going to go right out of any hole in the hood. If not placed properly though it's going to do absolutely nothing... unless your not moving.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
So at least I know that they work pretty well..
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
