Whistler mod ponderance
Old Sep 28, 2005 | 09:46 PM
ArcticZ28's Avatar
Default Whistler mod ponderance
What if I don't scrape off all the chrome on the lights? I got spray paint specifically for plastic. Is the "chrome" not plastic? Will it not stick or what?
Also, what did you use to get down in the grooved part of the housing? This steel wool ain't doin much, it is still shiny.
Old Sep 28, 2005 | 10:38 PM
Onyx Z's Avatar
It doesn't necessarily have to be bare plastic in order for the paint to stick, just roughed up a little bit. Nothing is going to be touching or disturbing the paint that would make it peel or wear off once it is completely dry.
Old Sep 28, 2005 | 11:19 PM
ArcticZ28's Avatar
Thanks for the info. I just spent a good deal of time scuffing so I'm bout ready to paint. Here goes nothin.
Old Sep 29, 2005 | 08:30 AM
abadss's Avatar
yea i just scuffed the surface of mine with some steel wool, did the job quick and easy. good luck with the painting, take your time and it will be fine. you'll love the new look
Old Sep 29, 2005 | 05:26 PM
VSGLS1's Avatar
Yup, just need to scuff it up.
Old Sep 29, 2005 | 05:35 PM
foshizl's Avatar
just scuffed mine and primed them...
Old Sep 29, 2005 | 06:47 PM
ArcticZ28's Avatar
I just scuffed mine up as best as I could. Painted them last night. They look kickass. Will soon be putting VHT niteshades on the clear corners as well.
Old Sep 29, 2005 | 06:51 PM
minesfaster's Avatar
WHats vht night shades ? ALso who all has painted the whole inside of the headlight ? I just painted the rim of mine.
Old Sep 29, 2005 | 07:21 PM
SScreaminDemon's Avatar
If you paint the whole inside, you're going to have trouble seeing at night. The light won't reflect.
Old Sep 29, 2005 | 10:02 PM
ArcticZ28's Avatar
It's a DIY smoke spray that you can smoke your lights with.
Old Sep 30, 2005 | 03:20 AM
cool thanks
Old Sep 30, 2005 | 09:03 PM
1FASTZ28's Avatar
When doing this mod how much of the headlight do you paint, just the front most part of the housing or do you paint in towards the middle a little too? I know you don't go all the way so the light will be reflected but I was just wondering how far back to go with the paint and how much I need to tape off, I plan to do this mod very soon along with wet sanding and then polishing my lenses.
Old Oct 1, 2005 | 03:18 AM
You only paint the rim there is a write up on how to do it . Just use the search bro.
