Headlight motor
Headlight motor
Well my head lights are gone! I tried the 180 temp and thye still grind so im guess the the privious owner already did that. well Im going to get the metal gear but I also want new headlight motors. Where Can I get the motors from? I tried GM parts direct but could not find it...
the same thing happened to me while home on leave. My local dealer said I had to buy higher assy. meaning the whole motor at 300+ per motor so I emailed Brent Franker and got the brass gears from him. They worked breat and are still working well according to my uncle.
ya my headlights are doing something really weird too. when i turn them off or click my alarm on or off they pop up by themselves then go back down and the motor makes a lot of noise. this seems weird to me .
That's common when the headlight motors go out. They'll pop up and go back down when you lock or unlock doors or set alarm. They will also pop up when you put your parking lights on. Not all the way over just the parking lights. I put the brass gears in one of mine to fix it and it lasted about six months before the epoxy cracked and it started making the noise again. Took it all apart again..used a liberal amount of epoxy and this lasted about a year before it started grinding the brass gear. Yes, I made sure the motor housing was firmly attached to the plastic gear housing also. Sometimes the tabs holding the motor to the gear housing is loose...factory fitment. This can also lead to stripping of the gear but I covered all the bases and still have issues. I so want to go to a fixed projector headlight but no way am I spending $999.99 for the only kit (breathless) out there. Anyone have any luck fabricating there own? I've searched different boards and seems like everyone gives up making there own fixed lights after a few tries.
