my conversion from 95 to 02 front clip
thanks to all of you guys boyd, xxxtransam and every body else who help me
So did you drive it around any with all the different colored body panels? That would have been fun
For some reason the LT1s look more sleek and less bulky than the LS1s (in that area, over the top of the wheel, as if the LT1 body sits lower on it's suspension points and was cut appropriately - I'm not saying it is, just trying to describe the look)
See what I mean? It's hard to describe, but the fender itself looks taller on the LS1 (from the top of the opening to the top of the fender), this makes the car look like it's bulkier and sitting higher. It's about the only thing I don't like about the LS1 look.
on a side note nice to see someone else driving a multi colored car for awhile.. LOL i drove mine for a month or so before i got in a booth.
as for the fenders... the are completely different. there is no way to alter a 93-97 fender to fit correctly.
speaking of fenders.. did you get the new brackets to go with the fender/bumper?
anyhoo nice job... if you have any questions about anything send me a PM...
as for closing the gap a couple thing to look at... if you take the headlight cover off there are 3 adjustments there. if you loosen all 3 you can play with it... once loosen it will make more sense. you will need a very small torq head to loosen them up.. after you have adjusted tighten back down and lay the headlight cover on top... don't worry about screwing it back in... then lower the hood slowly... and check for clearance. Then adjust as needed.
one thing you should know is the headlights open at an angle. so there will be some over lap of the headligth cover and the inside lipe of the fender.... I"ll see about taking some pics of all teh lines on my car to give you some ideas... also one thing you will notice... which i've failed to mention is you hood might not seem to fit right... thats because your hood stops aren't touching... you will need to get a set of channel locks or something and bend your current brackets upwards... if you replaced these props to you i'm doing mine later but i made them fit for now. the hood stops really do make a difference in the way the hood fits...
