Need help with tach install
Old Oct 15, 2005 | 04:25 PM
01ls1lover's Avatar
Default Need help with tach install
Car is a 2001 WS6 need instructions for all wiring and pix if possible any help is appreciated thanx in advance...
Old Oct 15, 2005 | 04:27 PM
parbreak's Avatar
Is this for an aftermarket tach like an Autometer?
Old Oct 15, 2005 | 04:29 PM
01ls1lover's Avatar
Yes its an auto meter tach with shift light
Old Oct 15, 2005 | 04:34 PM
01ls1lover's Avatar
Anyone.................?
Old Oct 15, 2005 | 04:42 PM
parbreak's Avatar
Damn dude I'm workin' on it for. Here is a link to the PDF file straight from Autometer's website. Download the 5"Tach with shift light instructions:
http://www.autometer.com/tech_instructions.aspx?sid=8
Everything is pretty self explanatory but the important part that they don't tell you because it's specific to each car is where to tap into the computer for the engine speed.
You will need to tap into the #10 pin on the red Connector C2. It is the connector that is closest to the front of the car. The one closest to the firewall is the blue connector. Take an 18-22 gauge wire tap and find the solid white wire coming out of that connector and tap into it. There are a couple other solid white wires so you'll need to make sure you have the #10 pin by actually pulling out the connector and counting over to 10.
Old Oct 15, 2005 | 05:55 PM
01ls1lover's Avatar
I dont know were to tap into the the ignition wire too.. the green one on the tach...
Old Oct 15, 2005 | 06:35 PM
parbreak's Avatar
The green wire is the wire that goes to the #10 pin on the PCM.
The ignition wire is red and gets hooked into any hot wire.
Old Oct 15, 2005 | 06:49 PM
davered00ss's Avatar
Moderator
Pic's at installuniversity.com
Old Oct 15, 2005 | 06:51 PM
01ls1lover's Avatar
where at in the vehicle in the passenger area or dash can i find the #10 pen wire thingy?
Old Oct 15, 2005 | 07:03 PM
2K2WS6TA's Avatar
If you're talking about the #10 white wire, it's in the engine bay, up near the firewall on the passenger side, look for the PCM (big box with lots of wires coming out of it)
here's the link to the install university article
http://www.installuniversity.com/ins...sity/index.htm
Old Oct 15, 2005 | 07:06 PM
01ls1lover's Avatar
theres about 4 white wires coming out. how do i find the number 10 pin?
Old Oct 15, 2005 | 08:46 PM
parbreak's Avatar
Pretty sure I just explained that in one of my above posts. You will have to pull the actual connector out of the PCM, that's the computer thingy in the engine bay, and count over to the #10 pin that has a solid white wire connected to it.
