another halo question ..sorry
Old Oct 22, 2005 | 03:31 PM
z28_n_tx's Avatar
Default another halo question ..sorry
just got mine today...i've already taken the stock head lights off and im about to put the halos in but i was wondering about the wiring part...i want to connect it to my fog lights that way i will already have a switch to turn them on/off when ever i want...where should i cut the fog light wire at?? what about the white wire comingout of the halos ???
thanks guys
Old Oct 22, 2005 | 04:04 PM
Lithium's Avatar
SSU's Drunk Typing Whore
White is the ground.
Then from what I remember you tap into the purple wire on the fog light.
Old Oct 22, 2005 | 06:19 PM
Ell Ess Won's Avatar
splice them both in, and kill your auto headlights.
Old Oct 22, 2005 | 07:23 PM
oodahss's Avatar
how do you get rid of the auto headlights
Old Oct 22, 2005 | 07:33 PM
It's called reaching up into the dash and actually taking out the sensor. It's at the top next to the red blinking security light and twists out.
Lithium's Avatar
You just pull a clip out from behind the radio, took me serioulsy 15 minutes to do. I ll find the link for ya...
Old Oct 22, 2005 | 07:35 PM
Lithium's Avatar
http://www.xse.com/leres/ss/drl.html
Old Oct 23, 2005 | 12:37 PM
z28_n_tx's Avatar
i just finish puting in my right halo headlight and theres a gap about maybe 1'' in between the actual head light and the front fender area, did any have this same prob?? what can i do to fix it?? heres a pic of where the gap is located.
http://i25.photobucket.com/albums/c9...a/b82160e5.jpg
Old Oct 23, 2005 | 01:01 PM
Lithium's Avatar
Did you reuse the stock headlight brackets? cause it will help with the gap. Even then some people still have a gap with reusing the stockers.
Old Oct 23, 2005 | 01:18 PM
z28_n_tx's Avatar
sure did, funny thing is that my left one went in very easy and fast and almost no gap. from far away they both look the same but obviously up close you can notice the gap on the right side....i hope i can find away to fix that.
Old Oct 23, 2005 | 03:29 PM
z28_n_tx's Avatar
took the sensor out but now when i go to turn my fogs on they wont come on....so had to put it back in so the fogs would come on
Old Oct 23, 2005 | 05:26 PM
FloridaZ's Avatar
Thumbs up
If you pull out your radio...looking into the area were the radio was.....there is a small box in the back on the upper right side. There are 2 plugs. Unplug the smaller one. That's all i did to disable my drls, and everything works fine. Although i did go ahead and wire the halos to there own switch so i could have them on whenever i want. Also gonna have them red soon. Should grab some attention at night at test and tunes
Old Oct 23, 2005 | 05:33 PM
FloridaZ's Avatar
here's the link
Old Oct 23, 2005 | 06:27 PM
z28_n_tx's Avatar
Originally Posted by FloridaZ
kool, thanks.... well i just took my car for a drive, its finally getting abit chilli here in tx...well got back took a look at the halos and the F*****G passenger side seems to have aleak...WTF.... i thought new products didnt have deffects ...before i install them i put some rtv around the edge to prevent that from happening in the future...i bought them off of ebay from XRTEAM...has any one delt with them before?? i hope they can replace it i mean its new just got them yesterday...
Old Oct 23, 2005 | 10:00 PM
z28_n_tx's Avatar
any one???
Old Oct 23, 2005 | 10:48 PM
I sealed the **** out of mine after I put them in, because they were foggin.
Old Oct 24, 2005 | 06:20 PM
z28_n_tx's Avatar
what did you use??? obviously you have to take them back out right??
Old Oct 24, 2005 | 06:58 PM
Roarin_8's Avatar
I got mine from XRTEAM and no problems with leaking. My gap is bigger on the passenger side than the driver's side and I used the stock brackets as well. Did you use wire taps to tap the halo wire to the fog wire? They made it very easy and I used the wire tap to short out the light sensor.
Old Oct 24, 2005 | 07:18 PM
z28_n_tx's Avatar
sure did, i got everything straight now, but i dont think i like the look of th fogs being on at the same time as the halos....any who...im taking the car out to see if there will be any more leaking...Xrteam didnt reply back , emailed them yesterday..
Old Oct 24, 2005 | 07:23 PM
Roarin_8's Avatar
I don't think that they reply back to emails or they're extremely busy to. A member here made a seperate switch for the halos so that he could turn them on whenever he wanted. Do a search and you'll find it.
