Battery Relocation Pics
Old Oct 30, 2005 | 09:27 AM
parbreak's Avatar
Default Battery Relocation Pics
Posted this in the External Engine forum but thought I'd post it here too since I did it mainly as an Appearance Mod:
Here are some pics of the hatch end of my battery relocation. Used an Optima Red Top, AFCO battery tray(same as BMR only $60.00 cheaper from Summitt) , 2/0 Gauge Positive Wire(probably overkill but wanted to be safe) and 2 gauge ground wire, and 200 Amp inline Type T fuse.
Here's an overall shot of the setup:
Here's a shot of the 200 Amp fuse:
Here's a shot of the 2/0 gauge + wire. This is a big *** wire at 5/8" diameter:
Bryan
parbreak
Old Oct 30, 2005 | 09:57 AM
2000blackta's Avatar
wow, that looks sweet. very simple and clean. i am eventually going to have to get around to doing that (hate the look of the optima under the hood).
Old Oct 30, 2005 | 11:57 AM
parbreak's Avatar
Pretty simple install. Hardest part was routing the 2/0 gauge wire under the carpet where the passenger seat mount is. Otherwise routing was pretty easy because even though the wire is huge, it's still pretty flexible.
Old Oct 30, 2005 | 03:54 PM
76LS1BIRD's Avatar
Restricted User
Default 98 Ta
I put my battery on the left side so that I could keep my spare tire. I used number 1 cable to run to the front. Tray was $10 @ NAPA
The block now has a lexan cover. This bolts in stock bat. tray.
more relocation info.
https://ls1tech.com/forums/generation-iii-external-engine/388581-battery-relocation.html
Old Oct 30, 2005 | 04:05 PM
Brandon Boomhauer's Avatar
looks nice,(from the other thread) do you have to use a dist. block at the front? or can you just make the wires long enough so that entire area is clear?
Old Oct 30, 2005 | 05:08 PM
parbreak's Avatar
Brandon,
There probably a lot of different ways of dealing with the front connections.
You could make the wires long enough, but I think that would require cutting the stock battery terminals off and splicing the wires together. I didn't do that in case I ever wanted to go back to stock, it would be very easy. Plus with the dist. block I can jump the car from the front if needed. And last but not least, I am making a cover for that area where you won't see the dist. block at all, so nothing ugly to look at. I'll post some pics when done.
By the way, I MAY have enough brass block left over if anyone wants to do this, I can send their way for a nominal fee
Bryan
parbreak
Old Oct 30, 2005 | 07:21 PM
meissenation's Avatar
Looks awesome! I'm going to have to do something like this soon as I need two batteries.
Old Nov 6, 2005 | 04:15 PM
76LS1BIRD's Avatar
Restricted User
Default fuse block
Added this to my 98 TA today.
It also has a cover. Dale
