Where to find grill insert?
Old Oct 31, 2005 | 09:28 PM
sscamaroburn02's Avatar
Default Where to find Grille Insert?
Does anyone know where I can get a grill insert that has camaro etched into the center with mesh on the side holes for the front of a 2002 camaro? I found one at RKsport but it had rksport in the center and not CAMARO...
Old Oct 31, 2005 | 09:51 PM
Default Where to find grill insert?
Does anyone know where I can get a grill insert that has camaro etched into the center with mesh on the side holes for the front of a 2002 camaro? I found one at RKsport but it had rksport in the center and not CAMARO...anywebsite would be helpful...
Old Oct 31, 2005 | 10:30 PM
Arachnotron's Avatar
Just pull the stock grille off and put some mesh in.
Fill in the holes and it will look really good.
Old Nov 1, 2005 | 12:18 AM
Schwindj's Avatar
Originally Posted by Arachnotron
NOt to hijack the thread or anything, but that has got to be one of the worst hoods I have every seen on a Camaro.
And yes just take off your stock black plastic grille, and you will have Camaro and a perfect place for some mesh
James
Old Nov 1, 2005 | 09:45 AM
paper doll's Avatar
try to do a google search is where i would search , but you may have more luck posting this in apperance and detailing section , more ppl who have experience with inserts and such
Old Nov 2, 2005 | 06:44 PM
J E T's Avatar
If you take your license plate cover off the front of your grille, you already have the grille that says CAMARO, it's just there are holes in it from where the license plate holder was. You can fill the holes, but if not...the only place I've seen that actually sells the grille that says Camaro is Thunder Racing for $45-50...
Old Nov 2, 2005 | 06:56 PM
GotV-8's Avatar
That hood is not that bad.
By Brett Foote | 2026-06-04 05:00:17
