View Poll Results: Whistler Mod on my Red Z?
Yes
89.47%
No
10.53%
Voters: 38. You may not vote on this poll
Whistler Mod, Yes or No?
Old Nov 7, 2005 | 10:14 PM
Zymosis's Avatar
Ahh yes, I do remember going up the aisle towards S&B's.
Back on topic, whats a good to use for the whistler mod? I know I have seen black, and grey/silver colors.
Old Nov 8, 2005 | 09:27 AM
abadss's Avatar
i say do it, it seems to clean up the front end, just take your time, its easy
Old Nov 8, 2005 | 09:32 AM
kyles2000z's Avatar
do it....just makes sure your headlights are crystal clear so you can see the black well. i painted mine thinkin my hazy headlights would easily be polished.....and it turns out i did all the work for nothin bc my headlights were too hazy to fix.
Old Nov 8, 2005 | 10:12 AM
GETGONE's Avatar
You guys realize you can buy the already modded black standard headlights from ProCar Parts right? http://www.procarparts.com/store-det...=onlinestoreDB
Old Nov 8, 2005 | 11:07 AM
Ling_650vette's Avatar
Yeah but the point behind the Whistler mod is 2 fold. 1) You're saving $$ being you arent buying brand new headlights and 2) you're doing it yourself. ~$10 is a lot better for my wallet than $150+ for brand new headlights.
Old Nov 8, 2005 | 11:10 AM
Originally Posted by Zymosis
Did it fog them up? Discolor them? Theres a sticky on here about cleaning up headlights. Sanding and whatnot. It is alot of work, but new headlights are damned expensive.
Made them look 10x worse. They were yellow and somewhat foggy, but now they're just straight up cateraks. I did wetsand them a bit, and used a plastic polish but it made them much much worse. Now you can barely see thru the lense.
Old Nov 8, 2005 | 11:15 AM
1FASTZ28's Avatar
I would also rather try and attempt it myself than pay $150 for new headlights. For all the supplies to paint the housing and polish the lens, it would be cheaper to do it this way, and I have the paint and sealant already.
Old Nov 8, 2005 | 12:27 PM
GETGONE's Avatar
Well I don't like screwing up orignal parts on a mod I'm not sure if I can pull off. It was also posted for those that have tried the mod and failed or have fogged lenses that really need new lights anyways.
Old Nov 8, 2005 | 12:38 PM
foshizl's Avatar
I did both the wistler mod, and cleaned up my lenses.. took some time but they came out way better.. ill try to post a pic.. when i get off work
Old Nov 8, 2005 | 04:22 PM
If you take your time removing the lense and take your time in masking everything its a fairly idiot proof mod. Those are the 2 "hardest" things about it. If you screw up the housing after that, then $160 vs $150 doesnt sound like that big of a deal. But $10 vs $150 is, at least to my wallet.
Old Nov 8, 2005 | 06:12 PM
BlackZCamaro's Avatar
Before.
After.
Definetly do Gloss. Mine are flat and it sticks out with the flash on.
Old Nov 8, 2005 | 06:36 PM
  #32
steveo346's Avatar
check out my page in my sig
Old Nov 8, 2005 | 06:44 PM
  #33
kyles2000z's Avatar
mine did the same thing
Old Nov 8, 2005 | 06:58 PM
  #34
What kit did you use if you dont mind me asking...cause if it was the same kit, I think others should be warned.
Old Nov 8, 2005 | 09:43 PM
  #35
6LITEREATER's Avatar
Do it or I am going to come over to your house and kick you in your @ss !
P.S. Do NOT use Gloss Black (from a can). Looks cheap IMO. Use LOW-GLOSS Black, looks like a factory mod then.
Do gloss black only if you are spraying it with a real spray gun and real car paint.
To me gloss black (from a can) makes the headlights look obviously spray painted. Just a personal thing...
Old Nov 9, 2005 | 11:40 AM
  #36
Craigz28ss's Avatar
What do you guys think about how much of the reflector should be painted. If you look at the two pics that were posted, the 1st one by minesfater only has the perimeter of the light painted. In the 2nd post by 1sicv6 the perimeter and the bottom portion of the light is painted all the way back to the rear reflector. I think this way looks a little better but I'm not sure how much this would affect the brightness of the headlights. If you guys have done this and know what way is better please post up your results. Thanks!
Old Nov 9, 2005 | 01:51 PM
  #37
steveo346's Avatar
nov 12th ls1 shootout wohooo!!!!!!!!!!!!!!!!!
Old Nov 9, 2005 | 03:01 PM
  #38
King James's Avatar
Do the bottom portion all the way back to the reflector. It doesn't effect visibility and I think it makes it look more like a factory thing.
I used a satin black.
Before
After
Old Nov 9, 2005 | 04:27 PM
  #39
I used semi-flat black. I painted the entire section going back to the reflector being it looks more uniform then. It may have effected brightness but not enough that I can really tell.
Old Nov 9, 2005 | 04:39 PM
  #40
Craigz28ss's Avatar
Thanks King James, looks good!
