Tint
Old Nov 10, 2005 | 06:29 AM
blue01ta's Avatar
Default Tint
What do you guys use at the top of the rear window where all the little dots from the rear defroster cause the tint to bubble up? I was planning on cutting that part out and painting but I would like to know which paint looks the best? The tint is 5%. TIA
Old Nov 10, 2005 | 07:37 AM
Snootch's Avatar
My tint guy used black vinyl on that part, then 5% on the rest of the window. You can't see any dots at all from the outside. I've heard of people painting this, but it sounds like it could be a mess, and a pain in the *** as well.
Old Nov 10, 2005 | 02:03 PM
Camaro Z's Avatar
My Brother tints windows on the side, and you cant fix the dots with tint. He somtimes buts a strip of black vinyl and thats seems to work
Old Nov 10, 2005 | 03:16 PM
Scotty-Z's Avatar
Just have the shop put a strip of black vinyl over it and it will work perfectly. That's how most good shops should do it.
Old Nov 10, 2005 | 04:35 PM
badtexasZ28's Avatar
you can also feather edge the dots out with some 600 grit sandpaper and some water, then apply tint over it
Old Nov 10, 2005 | 09:20 PM
Schwindj's Avatar
I would just sand the dots off. That way you dont have and weird little bubbles. Just my $.02
James
Old Nov 10, 2005 | 09:44 PM
Louie83's Avatar
I heard that you could use a strip of black vinyl and just put that over it.
Old Nov 13, 2005 | 08:54 AM
blue01ta's Avatar
Where can I get the black vinyl from?
Old Nov 13, 2005 | 09:13 AM
shortdo99's Avatar
I have mine tinted with no problems. I've used my defroster and it hasn't had any problems. I think if it is installed properly and you don;t use any window cleaner with amonia in it you should be ok.
Old Nov 13, 2005 | 09:14 AM
Elliottbrand.Com's Avatar
Yeah, the black vinyl works great. You can probably get a strip of it from a local sign shop.
Old Nov 13, 2005 | 04:18 PM
GETGONE's Avatar
Local guy here has his dots painted flat black. He showed me up close and unless you know what you're looking for it you can't tell it's been painted. The tint starts below that and is done in one piece. I'm planning on going to the same shop in the spring to have mine done.
