Polishing the AC condensor
take my advice mothers will never let you down!
i've made alot of money polishing stuff for people...and i always used mothers, up until a few months ago i started making my own polish...the key ingredient to polishing aluminum is elbow grease its like when chicks was their hair, u know lather, rinse, repeat and all that good stuff...well its the same with aluminum the more u polish it the more it shines...if u need and pointer feel free to pm me anytime...i'll post pics of all my polished stuff whenever i get a chance
If you don't have a LOT of time and PATIENCE, you might as well forget it.
I love looking at the finished work, and working on a part in the final stages, but all the prep work... nope.
Rough cast aluminum...had to get 80 grit to even begin to smooth it (at least thats what I did...!) Next was the water pump...another bumpy casting....I just wire brushed the hell out of it with my drill and many little dremel brushes. Then the TB and MAF. The TB is giving me problems with all the nooks and crannies..... Sometimes something seems to work but then not the next time!? The bolts to the TB...waterpump and intake manifold...and now the AC lines and all....And I thought I was one of the few doing this
My only worry is the longevity of all my HARD labor?? I figured I would have a fair weather car after all this as I do not want to become a slave to the engine on my weekends! Any info here would be nice....
I even covered all my wiring harness with non-split carbon fiber tubing....Took most al the connectors apart so the tubing could slip over the exhisting plastic wireloom....looks pretty sharp, kinda like carbon braid.. but what a pain to install.
where did you get this tubing material at...sounds pretty cool. TIA-Freddie
I just worked slow, cut to length and, after removinh and documenting connector pinouts as I went, slipped the sleeve right over the black split tube to maintain shape. I used a cigarette lighter to melt the cut ends so the loom would not fray before I slipped it on. Then I used vulcanizing black tape to set the ends near the re-attached weather pak connectors. I found some black split loom that was the same braid like the carbon fibre on line but liked the carbon look better. It is sold under the G-sport name and is called G sleeve. I tried using the shrink tubing provided for the ends but it was too hard to manage.
I would not do this again as it is VERY hard and time consuming removing the connectors, documenting their positions, and re-installing all the pins!!
Winter's setting in, so it's dang cold out here in MI, but now I got something to keep me busy this winter.
