side skirt question?
Old Nov 13, 2005 | 11:16 AM
95formulalt1's Avatar
Default side skirt question?
any one put side skirts off a ta on to a formula? was it hard what do i have to do to put them on? thanks
Old Nov 13, 2005 | 02:07 PM
RedRider81's Avatar
The main PITA is going to be drilling the holes to attach the side skirts. I don't have a write-up on this, but mainly what you have to do is line up the T/A side skirts on your Formula and then determine where the holes have to be drilled to attach them.
Old Nov 13, 2005 | 04:08 PM
that it? what about hole size?
Old Nov 13, 2005 | 04:10 PM
BLACKTA350's Avatar
or you could just buy a t/a ?!?!?!?
Old Nov 13, 2005 | 04:18 PM
could not fine one smart ***
Old Nov 13, 2005 | 08:09 PM
geo 95 bird's Avatar
GO 2 UR LOCAL AUTO STORE AND BY #8 SELF TAPPING SCREW BY 3/4 THATS FOR THE BOTTOM SIDE, ON THE UPPER SIDE REMOVE ALL CLIPS BY 3M DOUBLE SIDE TAPE NOT THE CHEAP ONE IT HAS TO BE THE ONE FOR MOLDINGS AND ROCKER PANELS IS ABOUT 11.00 BUCKS, CLEAN BOTH AREA WITH BRAKE CLEANER PUT THE TAPE ON THE SKIRT FIRST ALIGN IT U NEED 2 PEOPLE FOR THIS HOLD IT IN PLACE AND PUT YOUR FIRST SCREW HALF WAY ONCE THAT ONE IS DONE REPEAT THE PROCESS WITH THE REST. THEN PEEL OFF THE TAPE AND PRESS FIRMLY TO REMOVE ANY AIR THEN FINISH TIGHTEN THE SCREW SAME PROCESS FOR THE OTHER SIDE. ONCE THATS DONE U R GONNA NEED TO DRILL TWO HOLES THE SKIRT HAS A HOLE IN THE FRONT USE A 7/32 DRILL BIT, THEN USE THE CLIPS FOR THE FOAM BUT SMALLER.
Old Nov 13, 2005 | 08:12 PM
RAIDER's Avatar
Where would be the cheapest place to find one, one of mine cracked
Old Nov 13, 2005 | 08:18 PM
EBAY
Old Nov 14, 2005 | 12:16 PM
thank you
Old Nov 14, 2005 | 05:41 PM
Originally Posted by 95formulalt1
thank you
what r u running v8 or a v6
Old Nov 14, 2005 | 05:55 PM
erkki's Avatar
Use double sided tape on the sides and use screws on each end underneath. It's a lot easier to fit. Mine have been installed that way for a year and I haven't had any problems.
Old Nov 14, 2005 | 06:35 PM
LT1 with some goodes
Old Nov 14, 2005 | 06:37 PM
www.cardomain.com/ride/2163349
Old Nov 14, 2005 | 06:52 PM
has u can see from the pics i need side skirts bad!!
Old Nov 15, 2005 | 01:00 AM
tylerdj's Avatar
I did it this way on my firebird as well, worked perfectly fine. Makes the car look a million times better too
Old Nov 15, 2005 | 08:57 AM
i will give a try! thanks
Old Nov 18, 2005 | 12:43 AM
Formula_X's Avatar
I havent heard of a Formula V6???
