How cold is too cold to wash?
Old Nov 26, 2005 | 09:31 PM
vodas00ss's Avatar
just ask yourself one simple question "exactly how big are my *****?
Old Nov 26, 2005 | 10:00 PM
Reject's Avatar
better yet ask yourself this, how high do you want your ***** to be in your body! aint gonna be no hangin sac while your washin!
Old Nov 26, 2005 | 10:05 PM
CULATR's Avatar
HMMMMMMM..... Well i have washed the vette and bird many times where i would wash the side and then go to rinse it off only to find that the side had turned to a sheet of ice before i could rinse it off
Old Nov 26, 2005 | 10:06 PM
ChevyZ28Thunder's Avatar
Its never to cold..
Old Nov 26, 2005 | 10:51 PM
Speed Density's Avatar
hashtagBMW
Its too cold to wash your car when..........after you wash, 5 hrs later you get done with work and walk out to your car and your door is frozen shut.
Old Nov 26, 2005 | 11:58 PM
zo6vette037's Avatar
I Live In Alaska And Have Washed My Car When It Was -27 Outside... Oh And My Wife Washed Her Camaro Out There As Well.
Old Nov 27, 2005 | 11:00 AM
Fratsit's Avatar
I wash mine IN the garage with the hose hooked to the hot water heater.
Old Nov 30, 2005 | 12:56 AM
FBDYLVR's Avatar
Its too cold... Yes I'm a so cal weather wimp
sky: partly cloudy (night)
Clouds Early/Clearing Late
High: 66°
Low: 47° sky: partly cloudy (day)
Partly Cloudy
High: 68°
Low: 49° sky: cloudy
Cloudy
High: 68°
Low: 52° sky: showers
Light Rain
High: 64°
Low: 45° sky: fair (day)
Mostly Sunny
High: 63°
Low: 41
Old Nov 30, 2005 | 07:03 AM
thetastelingers's Avatar
I remember doing that with my truck. next morning I was freaking out because I was almost late.....d'oh!
the freezing of water sux, cause you can't do alot with it.
and washing with hot water doesn't help, because it is soft water, and will freeze almost as fast. not to mention taking off the wax.
Old Nov 30, 2005 | 09:24 AM
DrEvyl's Avatar
teh PuRpL3z
I washed my Trans Am on Saturday and it was 38 degrees out. I used water from the outdoor faucet, but filled my buckets inside with hot water so my hands didn't get numb. Worked pretty good. The biggest pain in the *** was trying to put the hose away... they get pretty stiff when it's that cold and don't want to roll up.
But yeah, if it's warm enough that the water won't freeze on the car, I'll wash it.... but only if the car is really dirty and needs a bath bad.
Old Nov 30, 2005 | 12:21 PM
Somebody09's Avatar
Too cold? For me that's about 40 degrees, no wind. I washed my car last winter and everything froze before I could rinse it... soap sud and all.
Old Nov 30, 2005 | 01:27 PM
  #32
4mula4ever's Avatar
Well were i work we have a 100'x120' shop with 1 bay designed for washing so I really don't worry bout the weather. But i have washed both my 90 gta and 95 formula right after the other when is was about 30 out.....swore I'd never do that again.
Old Dec 14, 2005 | 02:45 PM
  #33
cartmanchevy's Avatar
In Minnesota, we stop washing at absolute zero. It goes from hotter than hell in the summer to insanely cold in the winter. The other state that requires both AC and heat in the same day. It got to -60 last winter in the North.
Old Dec 14, 2005 | 05:34 PM
  #34
elite22xl's Avatar
first line off the water heater goes outside at my house
Old Dec 14, 2005 | 08:40 PM
  #35
BlackZCamaro's Avatar
15 Degrees Farenheit. You wash it, rinse it, jump in it and blast down the road before it all freezes. If youre lucky, you will only have ice on the back half of the car. If not, good luck seeing where youre going, and getting out.
Old Dec 14, 2005 | 11:30 PM
  #36
ABadMother1999's Avatar
I normally just pull it in the garage (unheated), wash it, dry it, wax it, and pull it out, squeege the water out, and pull it back in... Works good for me even on a cold *** day!
I do the same for my motorcycle, but the motorcycle never leaves the garage in this weather!
Old Dec 15, 2005 | 01:41 AM
  #37
jimbonzzz's Avatar
I wouldn't wash below maybe 45 degrees...
Old Dec 15, 2005 | 01:48 AM
  #38
Schwindj's Avatar
If the water can come out of the hose it is warm enough. I have washed a car with gloves on once or twice in my day.
James
Old Dec 15, 2005 | 11:12 AM
  #39
YoungGunLs1's Avatar
I go to the car wash and wash the car even when it is below zero, I dry it off, as well as inside the doors to make sure they dont freeze shut and I am good to go, I don't let cold weather keep my car dirty..winter time is when it needs to be washed the most.
Old Dec 15, 2005 | 01:03 PM
  #40
skippytheloon's Avatar
I've washed my car while it was snowing on me a few times. Easier to wash in the rain/snow...I agree that if the water can come out of the hose its warm enough LOL...I never take my car to pressure washer, strickly by hand, but I'd think that pressure washer+ice=bad.
