billet fuel door?
Old Dec 6, 2005 | 11:09 AM
SSclint01's Avatar
Default billet fuel door?
What do you guys think of the billet fuel doors on f-bodys, anyone know where i can get one?
Old Dec 6, 2005 | 11:23 AM
GotV-8's Avatar
Ebay, its the eclipse fuel door.
Old Dec 6, 2005 | 11:50 AM
~JOSHUA's Avatar
Please don't.
Old Dec 6, 2005 | 01:36 PM
GETGONE's Avatar
SEARCH!!! There's already a big thread with pictures on this from the other week.
Old Dec 6, 2005 | 08:29 PM
00turboT/A's Avatar
I Smell RICE
Old Dec 6, 2005 | 08:35 PM
kolkid's Avatar
try ebay and well since you are asking what *we* think I will go a head and tell you what I think.
that they are f*cking gay thats what I think
Old Dec 6, 2005 | 09:07 PM
JerseyLS1TA's Avatar
I don't like them and I would never have one on my car, but you can find them on eBay.
Old Dec 6, 2005 | 09:35 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
http://cgi.ebay.com/ebaymotors/MITSU...spagenameZWDVW
that the one?
Old Dec 7, 2005 | 05:09 PM
Blown Ta's Avatar
yea thats the one. if you paint it to match your car it will look good.
thats what i did and it looks awsome.
thats just my opinion, if you like the billet look, thats fine too.
btw you can see pics of it on my webpage.
Old Dec 7, 2005 | 05:31 PM
Sgt. Spuds's Avatar
how do you install it?
Old Dec 7, 2005 | 07:58 PM
BitViper's Avatar
Check this thread for more
https://ls1tech.com/forums/showthrea...=414744&page=1
Its fairly straight forward
You'll need some washers that are ~1/4 - 3/8 in OD...and that fit the bolts that came with the new fuel door.... you'll use them to sandwich your new door and the car body together....
You'll find it easier too if you remove your rear tire and wheel and loosen up the black body panel inside your wheel well...it just has some plastic screw keepers
1. Open your fuel stock door...you'll see some pop rivets that circle your door...get a drill thats just barely larger than the size of the center of the pop rivers... and drill them out..
2. Pull the door off
3. If your going to re-use your plastic overfill catch thingie youll have to mod it by notching it where the screws on the new fuel door will pass thru it and notch it or drill out holes for them to pass thru... if your not going to re-use then proceed on to step 4.
4. Press the new fuel door against the outside of the cars body. and at the same time place the bolts that came with the fuel door thru the holes on the fuel door...and thru or around the catch cup if you used it they will not need to go thru the body of your car. in fact I dont think they even come close..
Anyway...use the nut and washer to "sandwich" the body of the car between the washers and the fuel door. Dont over tighten so that you can make minor adjustments for fit as you go.
5. Do the same for all bolts on the cover put everything back.. then check the fit and tighten everything down
6. Have a beer...your done
This took me about 35 minutes..its very straight forward....If you do a neat job at drilling out the stock fuel door you can very easily roll-back your mod to stock...
