FYI on the LED Interior kits
Old Dec 22, 2005 | 04:55 PM
Z28LS1camaroguy's Avatar
you will need 5 of them
Old Dec 22, 2005 | 05:26 PM
slimcracka's Avatar
i personally would not spend that kinda money and have to go threw that much trouble...and then have the head unit not match....for my 2 cents i would go the wedge type...
Old Dec 22, 2005 | 05:27 PM
slimcracka's Avatar
and great job on the install and write up ***! lol
Old Dec 22, 2005 | 05:29 PM
LETHL_SS's Avatar
Originally Posted by slimcracka
i personally would not spend that kinda money and have to go threw that much trouble...and then have the head unit not match.....
Thats when you buy a kick *** head unit that can change the color to match
Old Dec 24, 2005 | 11:09 AM
slimcracka's Avatar
Old Dec 28, 2005 | 11:47 PM
s.o.m.SS's Avatar
still cant decide what color to go with... any help?
Old Dec 29, 2005 | 06:57 AM
LETHL_SS's Avatar
^ I think you would like the blue. Here is a finalized shot of my stereo section with my new head unit.
Old Dec 29, 2005 | 10:23 AM
s.o.m.SS's Avatar
that is bad ***, is there a way to fix the redline? on a scale 1-5 for a beginner in the electric deal what would you say this was?
Old Dec 29, 2005 | 02:00 PM
LETHL_SS's Avatar
The redline does show up in person but its not nearly as bright.... I have a shift light so I'm not worried about getting it any brighter.
If you go with the bulbs from superbrightleds, it would be really really easy.... all you would have to solder would be the headlight LED and the others are plug and forget. To do it right, LS1_SS's kit needs to be soldered like I mentioned in the original post and that takes a lot of time. Its not hard though. On a 1 to 5 scale I would say about a 2.
If you've never used a soldering iron you should practice tinning a wire and see how it goes. Once you can get that down looking good you should be able to tackle the bulbs.
Old Dec 29, 2005 | 07:59 PM
s.o.m.SS's Avatar
bad ***... thanks for the help... pm will be sent!
Old Dec 29, 2005 | 08:55 PM
keliente's Avatar
LETHL_SS (tommy)
I have done the door lights as well, they were very simple! Don't hesitate. You needn't remove the whole door panel either, just the trim around the door handle. The door light twists out. I didn't even solder my LED/resistor in, and it doesn't move around at all. It looks really neat @ night shining blue on the switches, too bad it is impossible to take photos of!
I would also like to add that for those of you who like to do it yourself, eBay is the best place for LEDs. I got 100 LEDs with 100 matching resistors for a 12v system for $11, shipped.
Old Dec 29, 2005 | 08:59 PM
  #32
keliente's Avatar
I can't see from your pics or not if you have done your ASR/foglight switches, but those were easy too.
Here is my stuff (very similiar to yours!)
The guts of the foglight switch, with two new LEDs ready to go:
My headlight ****:
My HVAC:
Gauges at night:
Gauges during the day:
Old Dec 29, 2005 | 09:14 PM
  #33
LETHL_SS's Avatar
I did do the door lights and still have some bulbs left over... I may tackle the foglight switch tomorrow.... my ASR is disabled so I dont have a bulb in it anymore.
I'm still contemplating doing the steering wheel controls even though they are inoperable with my Eclipse deck (may get the pac adapter at some point).... I attempted earlier and got tired of messing with it.
Old Dec 29, 2005 | 09:22 PM
  #34
keliente's Avatar
Yeah I lost my steering wheel controls when I got my audiobahn
Someday I'll get the adapter.
Here's a how-to someone wrote on doing the steering wheel lights. I have yet to do them, for now I just pulled the fuse so they don't mismatch.
https://ls1tech.com/forums/showthrea...wheel+controls
Old Dec 29, 2005 | 09:38 PM
  #35
LETHL_SS's Avatar
I soldered in the LED with the load resistor and never could get it to turn on (even desoldered and flipped it). Tried putting the original bulb back and still no luck.
On another note, my Elcipse deck has the prewiring for the steering controls but it has two wires for it when the stock deck only uses pin 14 on connector C3.
Old Dec 29, 2005 | 11:43 PM
  #36
s.o.m.SS's Avatar
lethl_ss ... your name is tommy? thats fucked up... same car and everything
