Pics of gauges in AC vents in my TA
#41
Ive never seen the gauges in the a/c vents but they look amazing ......sweet car JayPee...but i have a question for you...since the gauges are there does that mean you hve to block off the vents when you use ur a/c or heat or do you just only run the fan on other positions...the reason i ask is becuase i didnt know, im not trying to be dumb
thanks,
seth
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
thanks,
seth
#42
there is one "tube" that blows air through the 3 middle vents. I blocked that off. Now the air blows "three times harder" through the side vents. I did a test during the summer to see if it was tolerable and its not bad at all.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#45
Werd. Great job, your car looks kickass.
I did two Autometer Cobalt 2 1/16" gauges in the driver side vent (trans temp) and far left center vent (boost).
I made mounts for the 2 1/16" gauges out of black plastic stock (CD case and a dremel works great for this !).
Later I found some carbon fiber trim rings at a motorcycle shop that fit perfectly too (not shown here) !
Rob (Bad30th)
![](http://memimage.cardomain.net/member_images/3/web/435000-435999/435130_121_full.jpg)
Rob (Bad30th)
#48
I love the outside of the car. Though the rear bumper insert could be a couple shades darker. Still, very nice. Like the wheels.
I don't like the placement of the shiftlight though. I am also not partial to white faced guages. They contrast too much with the rest of the cars interior. I do like the clean install of the guages in the AC vents. Very nice.
#49
that little vent on the a pillar is a cool place for a shiftlite, ive seen pics of one installed there before. love the gauges in the vents. im gettin an AFR gauge for the driver far left vent
