clay bar help
Old Jan 3, 2006 | 01:30 PM
PDQ-TA's Avatar
Default clay bar help
I did the claybar treatment and had some questions if I did it correctly. I used the Mothers kit and the spray that came with it. The clay seemed to glide very smoothly across the paint and very little grim was left on the bar. Did I use to much of the spray. I did the plastic bag test and it did seem to be working, I just thought there would be more stuff left on the clay.
Old Jan 3, 2006 | 01:51 PM
chupr0kabra's Avatar
If the paint surface feels smooth and doesn't have a gritty texture, the claybar worked. I've never used too much spray, and I'm not sure it's possible.
-Mike
Old Jan 3, 2006 | 02:17 PM
Zymosis's Avatar
Maybe just not many surface contaminents. I used the same kit, and used plenty of the lube that came w/ it. I really don't think you can use to much, just make sure it slides, and it is nice and smooth when you are done.
My bar had some dirt in it, especially after doing around the bumper.
Old Jan 3, 2006 | 02:43 PM
Bad Blu Formula's Avatar
As long as its smooth when you're done, thats all that matters.
Old Jan 3, 2006 | 02:49 PM
Dustin's Avatar
-Mike
Exactly, if its smooth then you are good to go.
Old Jan 3, 2006 | 03:07 PM
SmokeySS's Avatar
Just wanted to add in that my clay bar kit said you can't use too much of the spray solution - so no, it's fine.
Old Jan 3, 2006 | 09:34 PM
hammerhead's Avatar
Ditto. I use LOTS of spray. I ususally put a piece of cardboard under where I'm working to catch the runoff. Lots of detailer spray is good to insure you don't scratch the paint. If your claybar didn't pick up lots of junk, the paint must not have had too many enbedded contaminates to begin with.
Old Jan 3, 2006 | 09:45 PM
Reject's Avatar
yeah i remember the first time i did mine and it didnt feel like i did much, but once it came time to washin and waxing later weeks, wow you could really feel it when you were scrubbin with the soap!
Old Jan 3, 2006 | 09:53 PM
ThatGuySkye's Avatar
formerly mystic-t/a (changed 02/05/2013)
The more QD (aka "spray") the better, its there to lube and make sure the clay bar doesn't scratch the surface. It is way worse to use too little. If you run out you can always buy more, if you dont use enough then you have to polish out the scratches.
Old Jan 4, 2006 | 04:16 AM
Flawless02SS's Avatar
If you see too much stuff if any at all, you cars' paint was in very bad shape. Lots if spray is needed, I almost used 3 bottles.
Question: Does detailing spray have to be used during claybaring, car soapy water be used?
Old Jan 4, 2006 | 05:11 AM
Formy's Avatar
You can use regular water with the clay bar if you wanted to. As long as the surface is constantly being lubricated while claying you got nothing to worry about. Circular motions, constant lubrication, very little pressure, this is all you need to do to clay your car.
Old Jan 4, 2006 | 11:05 AM
PDQ-TA's Avatar
Thanks to all that have responded, This site is awsome. If you don't know just ask. Someone somewhere has gone thru the samething. Now that my car is nice and smooth, will that inprove my ET?
Old Jan 5, 2006 | 01:35 AM
On a cool enough day you can actually clay after you wash and before you dry, using the soapy car wash water. Or you can mix up your own mix of soap and water in a spray bottle.
