converting diamond halos to black halos
Old Jan 4, 2006 | 02:42 AM
phillyz28's Avatar
Default painting diamond halos black
i got a set of diamond halos basically for free but i wanted to make them the black halos instead. i have no idea how to do this or if its possible so all help would be appreciated
Old Jan 4, 2006 | 04:11 AM
1SicV8's Avatar
i would assume u can do it the same way as the whistler mod.
1. take headlights and place in 400 degree oven for 20 minutes
2. once out use a butter knife and screwdriver to pry open the housing, careful not to break them, take ur time, if they do not come apart easily, place back in oven for additional 5-10minutes
3. now that they are apart, tape off what areas u do not want painted. next use some black spray paint to paint the areas u want black
4. once paint is dry, use some clear rtv sealant to place healights back together, dont use too much or itll leak on the inside of lights
BAM UR DONE! let me know if u missed anythng guys
Old Jan 4, 2006 | 05:25 AM
JustAnIlluzion's Avatar
1. sell them on ebay
2. buy the ones u want on ebay
Old Jan 4, 2006 | 10:30 AM
Z28-CTYHNTR's Avatar
Much easier. The halos arent quite as sturdy as the OEM headlight housings.
Old Jan 4, 2006 | 11:47 AM
phillyz28's Avatar
you are prolly right
Old Jan 4, 2006 | 12:03 PM
Guy2626c's Avatar
opening up the headlight is really easy. I have the black halo inserts out of my lights right now for some mods i want to do. It took 5 minutes in the oven, and they pried right open.
Old Jan 4, 2006 | 12:38 PM
phillyz28's Avatar
you really put headlights in the oven? like the whole thing? does the plastic molding melt off or anything
Old Jan 4, 2006 | 12:41 PM
monicaz28's Avatar
I wouldn't do it. I'd just sell those and get the ones you want.
Old Jan 4, 2006 | 04:03 PM
1SicV8's Avatar
yes really in the oven, it just loosens up the glue that holds them together
Old Jan 4, 2006 | 04:09 PM
kyles2000z's Avatar
the ebay sellers aren't carrying black halos right now, i assume they will shortly tho
Old Jan 4, 2006 | 07:54 PM
Arachnotron's Avatar
I'd just buy some that are already black. I have tried to take a set apart, but the glue is not the same as on the stock headlights.
Old Jan 4, 2006 | 10:35 PM
1SicV8's Avatar
anymore info on when u tried, process u used etc
