HVAC LED modding pics
Check out my new glowing *****. I just peeled the rubber boots off the stock *****, and presto - the magic works itself. What do you guys think? I like it, and it looks even better in person.
Originally Posted by The Sad
I kinda like it, but what does it look like in daylight with the lights off?
Originally Posted by 5.7LoFuN
how did you get all your other lights blue like the one on the radio and fog lights/ ASR....also can you get the blue on the steering wheel buttons ?
http://www.xse.com/leres/ss/leds.html
Yes, the steering wheel controls can be done as well as the foglight switch, and various other lights as well.
Looks bad *** if you ask me. I may do the same thing to mine but in red, red and black are my car colors. As for the glowing shift *** comment, the only reason you don't like it is cause ricers are known for it. If an F-Body guy would have been the first to do it you would probably think it's cool. That's not a slam, it's the same way I feel but I am slowly getting over it.
On a side note, will the rubber boots come off of the radio tuner and volume **** as well? That would be the ****
Originally Posted by Luna
WOW! That looks awesome, I am definetely going to try that this week!!
Those are really the stock **** minus the ugly gray rubber ??
Yep.. All you do is take a heat gun and heat them up for a while to get the glue unstuck.. Then just start peelin.. In a Camaro, I have never seen in done in a T/A so I have no idea if it looks the same.. But a way to check is to pull them off and look under then.. They will either be that yellowish white people are talkin about or they will be clear..
