removing SS hood grilles?
Old Jan 20, 2006 | 06:47 PM
SIK02SS's Avatar
Default removing SS hood grilles?
I've been searching for a while and can't find anything on it. How do you take out the hood grilles?
Thanks in advance
Old Jan 20, 2006 | 07:05 PM
SIK02SS's Avatar
ttt....
Old Jan 20, 2006 | 07:10 PM
GETGONE's Avatar
There's 4 tabs 2 on top and 2 on bottom. You have to take a screwdriver and CAREFULLY pry on the top or bottom to pop it out.
Old Jan 20, 2006 | 07:16 PM
SIK02SS's Avatar
damn, thats what i was afraid of! thanks a lot!
Old Jan 21, 2006 | 10:19 AM
WayneSS01's Avatar
I take a twist tie and shape it into a hook. Thread it through a hole on one end of the grille and tie it off. Makes sort of a handle. Then I take a flat blade jewelers screwdriver, pry up the tabs and pull on the twist tie. The grille pops right out.
Old Jan 23, 2006 | 06:03 AM
pjb's Avatar
pjb
the tabs are flimsy and could break easily. be careful.
Old Jan 23, 2006 | 10:11 AM
hawaiiboysz's Avatar
I removed mine when I crashed into a light pole. I found the grill at the accident scene. 8 tabs held mine in I broke one messing around with it. Its kinda brittle so take it easy.
