View Poll Results: What are generally the three most important aftermarket guages to have?
water temp
45.98%
trans temp
55.56%
air/fuel
59.00%
voltmeter
4.60%
oil pressure
54.02%
fuel pressure
53.64%
aftermarket guages are useless
3.83%
Multiple Choice Poll. Voters: 261. You may not vote on this poll
Old 02-26-2006, 10:54 AM
doehmer's Avatar
what bennefits would you get from an oil temp. gauge?
Old 02-27-2006, 11:44 AM
Divergent Lightning's Avatar
The hotter your oil is the faster it breaks down.
I wouldn't put in an A/F gauge unless it is hooked up to a wideband, otherwise it is just useless.
Old 03-12-2006, 02:44 AM
LetMeBurnU's Avatar
Water temp & Vacuum guage
Old 03-12-2006, 09:58 AM
chupr0kabra's Avatar
Bling meter.
-Mike
Old 03-12-2006, 11:01 AM
chaman's Avatar
Blinker fluid level gauge...
Old 03-12-2006, 01:14 PM
BlackHawk T/A's Avatar
Agree with Oil Temp, Coolant Temp, and Transmission Temp.
However our stock tachs suck...I would also get a Tach and if you are using N2O, bottle & fuel pressures. If FI, boost PSI and fuel pressure. That's a lot of gauges though
Old 03-12-2006, 02:49 PM
cooltc2004's Avatar
trans and water temp and fuel and oil pressure. Those are the most useful imo.
Old 03-25-2006, 12:20 AM
Ferocity02's Avatar
As mentioned, depends on your set-up...
Any F-body 99+: Water temp gauge is nice to have
Forced induction: Boost, Fuel Pressure, and WIDEBAND A/F gauge
A4 Tranny: Transmission temp gauge
Road Racing/LOTS of hot city driving: Oil temp gauge
Nitrous: Nitrous pressure and nitrous temp gauges
Towing: Exhaust gas temp gauge, tranny temp gauge
The A/F gauges from Autometer are pretty much useless because they are not wideband, meaning they give you stupid blinking lights insted of numbers. I had one, and it was fun to watch is bounce back and force like a retard, but other than that, it was a waste of money. The voltmeters and oil pressure gauges are also useless, you them on your dash, use them. I suppose you might want an oil pressure gauge for accuracy, but the stock one is decent.
Old 03-26-2006, 10:47 AM
Roarin_8's Avatar
Old 03-26-2006, 11:59 AM
LS69TA's Avatar
Let me see if I can remember what my buddy is putting in his 91 RS TT project car:
oil pressure
volt meter
trans temp.
water temp (driver side head)
water temp (pass. side head)
fuel pressure
air inlet temp
boost
air/fuel wideband
pyrometer (drivers side)
pyrometer (pass. side)
oil temp.
clock
Seems like there was one more
Old 04-02-2006, 08:57 PM
Spenser309's Avatar
at a certain point you just need a datalogger that will set off a light if anything is out of norm.
Old 04-02-2006, 10:28 PM
  #32
LS69TA's Avatar
Yea, it seems like he's going to have some LEDs somewhere, and his laptop mounted in the car.
Old 04-22-2006, 07:07 AM
  #33
Honda Hunter's Avatar
I would say fuel psi, a/f ratio (wideband), and tranny temp. Anything the computer doesnt read or isnt accurate. I think the stock coolant gauge and the oil psi gauge are ok.
Old 04-22-2006, 07:11 AM
  #34
forgot about oil temp and vacuum gage.
Old 04-22-2006, 01:03 PM
  #35
VSGLS1's Avatar
Boost, N20, fuel pressure....
Old 05-18-2006, 09:18 AM
  #36
keliente's Avatar
Depends on what you're gonna do to your car.
A/F is ALWAYS nice to have, but only if it's wideband...a narrowband is just going to be some pretty LEDs to look at.
Water temp is useful, since your stock gauge is a dummy gauge (unless you are a 98). It'd be helpful in the staging lanes at the track and such.
Fuel pressure would be important if you were running some kind of forced induction...
I wouldn't do oil pressure, because the stock gauge is accurate.
Voltmeter is kind of unnecessary too imo.
Old 06-07-2006, 11:18 AM
  #37
grb
grb's Avatar
I put a dipshit-o-meter in mine. Goes off all the time!
Old 06-13-2006, 12:05 PM
  #38
CT ITALIAN 1's Avatar
I did A/F just 'cause it's fun to watch bounce back and forth haha, I know it isn't accurate at all. Also I did mechanical vaccuum and oil press. gauges.
Old 06-14-2006, 07:19 PM
  #39
chaman's Avatar
I will put a fart detector next.....really useful IMO
Old 08-07-2006, 07:27 PM
  #40
NYC FRANK's Avatar
Talking
OIL TEMP, TRANS TEMP and A/F here. Like was said before the Autometer A/F Is cool for a light show. I only put it there cause I had it lying around from another car.
Attached Thumbnails What are generally the three most important aftermarket guages to have?-interior.jpg
Quick Reply: What are generally the three most important aftermarket guages to have?
