Clear corners letting water in
Old Feb 3, 2006 | 01:27 AM
rainman's Avatar
Default Clear corners letting water in
I think the part where the main bulb goes in is damaged slightly. After a week or so of having a new bulb in there, water seeps in and the bulb blows. How can I seal it up well so that this stops happening?
Old Feb 3, 2006 | 01:43 AM
nhra-trans-am's Avatar
Moderator
permatex silicone should work
Old Feb 3, 2006 | 08:43 AM
Zymosis's Avatar
Mine would always get moisture in them if I only had the inside bulbs on, and not the outside ones.
I sealed everything up (but the drain holes) with RVT Silicone (clear) anyway because many clears are known to leak.
