What, if aything, dissolves POR-15?
Old Feb 7, 2006 | 08:18 AM
BJM's Avatar
BJM
Default What, if anything, dissolves POR-15?
I was sloppy and got some on my hands. I cannot find anything that will make it budge. I have tried:
WD-40
Acetone
Xylene
Gasoline
Varsol
Soap
Nothing worked. The can says a solvent exists but what is the base chemical?
At least I am better off than the guy who got Herculiner on his "Hootus".
Old Feb 7, 2006 | 08:41 AM
Xsta Z 28's Avatar
It's there for a while. It "bonds" to skin. It will wear off in time.
Old Feb 7, 2006 | 08:46 AM
BJM's Avatar
BJM
I was just hoping to speed things up a bit.
Old Feb 7, 2006 | 08:52 AM
H8 LUZN's Avatar
well i am sure there are chemicals that disolve it... just none you really want to use on your hands!!
~JOSHUA's Avatar
Skin cells die and fall off within 3-7 days. If you rub your hands 3 or 4 days after that stuff will come off.
Old Feb 7, 2006 | 08:58 AM
Firehawk0220's Avatar
Try Barryman's B-12. I haven't found anything it wouldn't take off. Actually, I don't know about using that on skin.
Old Feb 7, 2006 | 09:16 AM
TAbeba's Avatar
Very true
Old Feb 7, 2006 | 10:04 AM
Camaroholic's Avatar
I use nail polish remover (don't tell my wife) within a few hours of using the POR-15. Works well.
If it's fully dry and been a couple days....... well, time and rubbing/scratching is the only thing that'll take it off. Done that too...
Old Feb 7, 2006 | 10:55 AM
11SECSS's Avatar
try using some sandpaper like 400 grit
Old Feb 7, 2006 | 11:02 AM
TAbeba's Avatar
DAMN now that would hurt, or if you could use scrub lotion would take dead skin of and make your hand soft
Old Feb 7, 2006 | 11:15 AM
darkknight99's Avatar
That stuff is crazy......unless you use something immediatly...I mean within a split second...Your wearing the stuff for a couple of weeks....
Old Feb 7, 2006 | 11:22 AM
BJM's Avatar
BJM
I thought nail polish remover was mostly acetone (which I tried). Is there other stuff in there too that might help?
Old Feb 7, 2006 | 12:00 PM
I don't know what else it might contain, but it worked for me. I also have some POR-15 thinner that works to help clean up.
The biggest mess I made with POR-15 was when I painted this 79 Camaro subframe. And then I threw the subframe away when I moved, didn't even use it.
