A Beginners Guide To Detailing!
Old Feb 8, 2006 | 08:33 AM
CashMoney's Avatar
I'm trying to figure out why you use bug and tar remover prior to claybaring.. wouldn't claybaring do they same thing and eliminate one of the steps?
Old Feb 8, 2006 | 09:38 AM
meissenation's Avatar
Originally Posted by BlutVonSchwachen
I never use armor all on the interior, from my experince it would always resulted in cracking the dash from heat quicker...
that's an old myth. ArmorAll has switched it's makeup and will not dry out your dash anymore. this is old news.
Old Feb 8, 2006 | 10:12 AM
Commando's Avatar
HOT HOT HOT, thanks a million
Old Feb 8, 2006 | 03:48 PM
ryant430's Avatar
Claybar works best for removing imbedded materials and rough spots in the clear coat. The reason for using bug and tar remover before claybarring is to help keep the clay clean and full of less debris.
Second note...
It is perfectly safe to spray down an engine, avoid getting water into the intake and places were it may collect the water. So after cleaning the engine before running it always blow shop air into all the cracks and small holes to elimanate it from building up anywhere. Never start a wet engine or the belt is just gonna throw water all over your clean bay and leave spots everywhere.
Old Feb 12, 2006 | 10:20 PM
Trojan35's Avatar
I'm interested in the spray painting of the Fender/wheel wells. Can I get some more detail on that? On my black car, they're starting to look very gray-ish.
Old Feb 12, 2006 | 10:52 PM
ZaneO's Avatar
Originally Posted by 94whitez28
buff before wash so you can get the compound out of cracks
I do not recommend this practice (among a couple of others listed).
Clean them *throughly* and apply a tire dressing to them.
Old Feb 12, 2006 | 11:00 PM
1998TA__1991RS's Avatar
i always do a quick wash before i buff then wash again after
another thing you can do in the fenderwells if you dont want to spray paint is use any silicone based spray (tireshine,amorall,son of a gun) just make sure there is no wind or it will go all over the car
Old Mar 12, 2012 | 11:44 PM
n2o98T.A's Avatar
Im just glad im not the only one who removes my seats (front and back) just to clean the car. the neighbors always look at me funny when i do it
Old Mar 13, 2012 | 08:54 AM
BlackScreaminMachine's Avatar
Internet Mechanic
There is good stuff here, but every detailer knows they need to customize what they are doing based on the customers wishes and what they are willing to pay for. This is definitely a general guide as when you get into paint correction, IF you decide to correct the steps will change a little according to what you need.
This is my list which will translate to paying customers any my personal non-gratis projects such as my car and family members... I general break down interior, exterior, engine bay, wheels/wheel well.
THIS IS NOT PERFECT but I think helpful. PM me with questions.
-Exterior-
1) Inspection
- Take note of Trouble spots and Areas that need major attention.
- Decide the process in which to approach the vehicle, supplies, and time.
2) Pre Wash
- Good Mild soap, nothing with wax in it, no Dawn (due to pH issues). Good wash mitt, 2 bucket method
3) Clay
- Most times when doing correction you will need to clay the car, there or different types of clays out there in terms of aggressiveness. More aggressive will require correction.
- Using the Plastic Bag method (before washing) to feel for any texture is a great way to find areas that need it but in general the whole car gets done.
- With the car wet from rinsing, using a good non wax detailer for additional lubrication, I will clay the car ensuring removal of any surface containimates. *** This is the stuff that catches in a buffer that can damage the surface.
4) Re-wash
- To remove any left over clay and have a clean/dry surface to decide if your correcting or moving on to sealing.
- I use a good towel like Meguiar's Water Magnets, they absorb and low chance of swirling surface.
- Dry completely
5) Correction (optional) -This section should be a article in of itself-
- Tap off edges and or surfaces like trim, emblems, door handles/locks. 1" Blue or Green 3m tape.
- Paint Depth should be checked for the entire car and make sure you know how much clear you have to work with.
- Some cars need a rotary and then step down to a D/A to smooth. Or right to a D/A. Pad and chemical choice is dependant on the situation.
- Nice dark garage with good lighting for inspection of swirl marks, a hand held light can be useful.
- Re check paint depth and see how much you removed.
6) Re wash
- Be very careful, cleaned, leveled surface has no wax to protect so make sure to try to introduce as little of swirling as possible. Light pressure if none. A good compressed air for cracks. Slam the doors to make sure the car bleeds out.
7) Sealant/Wax
- Your choice; Carnuba or Synthetic, both have pluses and minuses. So do your research. There is no perfect way. It is the way that works for you.
- Do a light coat, buff off, and another light coat, then buff. The car should be allowed to cure (sometimes 5-8 hours or over night), The one final coat to give a solid protection layer.
- I recommend Meguiars Ultimate Quick Wax for in between wax boosting and the beading technology is impressive.
8) Final inspection
- Go over cracks, near trim, remove tape. Clean windows for the final pass.
- Look at different angles in the light to make sure left off wax residue has not been left on. I can be heavy handed so make sure you see no smears...
-Wheels/Wells-
1) Inspection
- Does the wheels need correction.
- Coated or Un coated metal.
- Does the wheels need removal.
- How does the wheels look??
- How aggressive does the chemical needs to be.
2) Rinse
- Spray down.
- Spray your choice of cleaner, be careful on un coated aluminum.
- Scrub with various brushes, semi stiff bristles.
- Rinse, inspect, repeat if needed.
3) Dress
- Dry wheels.
- Spray down with a chem of your preference. I prefer Meguiar's Hyper Dressing Mixed 1 to 1 (insane shine, last for a good week if not more).
-Engine-
1) Know your car!!
- Not all engines can just be sprayed with water. (See Optispark LT1 350's)
- A slightly warm motor is ok!!
- Spray down with degreaser of choice, allow for dwelling, and scrub w/ various brushes. Rinse, repeat.
- Dress with something that will make the black shine.
- Wipe down on fender edges and front radiator support.
-Interior-
1) Jamb the car with a good All Purp cleaner and a clean towel. Especially the tracks in the trunk, Also all door edges that are on the inside.
- Also will include wiping down gaskets and if needed wipe down with silicone as it helps keep the gaskets moist.
2) Inspect
- Look for stains, burn holes, dust and other trouble spots.
- Decide if you want to pull the seats (Purely optional)
3) Process
- Dry vacuumed with various brushes to agitate the carpet/floor mats. Vac cracks of seats as well.
- Small brushes for vents an other hard to reach places.
- Wash/wipe down of all hard plastic surfaces, consol, controls.
- Wash inside of windows (see car wash soap), wipe, then final wipe with a good cleaner.
- Protecting the seats (i.e. leather cleaner) and hard plastics. Avoid this stuff on dash mat, will lead to nasty glare.
Old Mar 14, 2012 | 09:39 AM
Gipraw's Avatar
Originally Posted by 1998TA__1991RS
what is the purpose of using 2 was buckets? ive never understood it, also what kind of shampooer are you using?
The two bucket method helps prevent you from inducing any kind of marring onto the paint by keeping the dirt you are removing out of your soapy water. One bucket full of car shampoo mixed at the proper dilution, one bucket full of clean water, both buckets with grit guards.
Mitt goes from soapy water bucket to car, then from car to clean water bucket to rinse off the dirt, then soapy bucket again, then back top car. repeat. Depending on how dirty the car is, you may need to dump and refill the water bucket multiple times.
Originally Posted by ryant430
Or one wash bucket is used for the sponge/mat and the other is used to keep the shammy wet. You can do all kinds of stuff with multiple wash buckets.
Different processes work for different people, but I hope you all understand that any place doing a full detail in just two hours is covering, not correcting, I don't care how many people are working on the vehicle.
There is a point where covering and concealing become a valid option, but the vast majority of the time, it is not the correct answer.
Using the dealer prep method of cleaning a vehicle is not something I would recommend anyone in this forum use on their own vehicles, or on their customers vehicles.
The original posters list of things to do is not a bad starting point. Just make sure you are using the proper technique and tools for each step.
